1. Integrating Facebook Lead Ads with Pabbly Connect
To automate lead notifications for your sales team, start by accessing Pabbly Connect. This platform allows you to connect various applications seamlessly. The first step involves setting up Facebook Lead Ads as a trigger within Pabbly Connect.
Begin by logging into your Pabbly Connect account and selecting the “Create Workflow” option. Choose “Facebook Lead Ads New Lead Instant” as the trigger event. This ensures that every time a lead is generated via Facebook, it will automatically notify your sales team.
2. Connecting Facebook Lead Ads to Pabbly Connect
Next, you need to connect your Facebook account within Pabbly Connect. Click on “Add New Connection” and follow the prompts to log into your Facebook account. Ensure that you select the appropriate page, in this case, “Prime Properties,” as this is where your leads will be generated.
  • Select “Prime Properties” as your Facebook page.
  • Choose the lead form associated with your ads.
  • Set the response type to “Simple” for easier data capture.
After setting up the connection, test it by creating a dummy lead through Facebook Lead Ads. This will allow you to verify that the data is being captured correctly in Pabbly Connect.
3. Sending Notifications to Sales Team Using WhatsApp
Once your Facebook Lead Ads are successfully connected to Pabbly Connect, the next step is to notify your sales team via WhatsApp. To do this, you’ll need to integrate the WhatsApp Cloud API using Pabbly Chat Flow. This will ensure immediate notifications are sent upon lead creation.
Begin by adding a new connection for Pabbly Chat Flow in your workflow. You will need to enter your API key from the WhatsApp settings in Pabbly Chat Flow. This allows Pabbly Connect to send messages directly to your sales team.
  • Go to the settings in Pabbly Chat Flow to obtain your API key.
  • Enter the API key in Pabbly Connect to establish the connection.
  • Specify the phone number of the sales team in the message settings.
Once this setup is complete, you can customize the message that will be sent to your sales team, including lead details like name, email, and phone number. This automation significantly reduces the risk of losing leads.
4. Testing Your Automation in Pabbly Connect
After setting up your automation, it’s crucial to test the entire workflow in Pabbly Connect. Create a new lead via Facebook Lead Ads once more to see if the notification is sent through WhatsApp. This step ensures that everything is functioning correctly.
Check your WhatsApp for the notification, which should include all necessary details about the new lead. If the notification is not received, revisit your connections and ensure all settings are correctly configured in Pabbly Connect.
By conducting this test, you can confirm that your sales team is immediately notified whenever a new lead is generated, thus enhancing your chances of conversion significantly.
5. Conclusion
In conclusion, using Pabbly Connect to automate lead notifications via Facebook Lead Ads and WhatsApp Cloud API is a game-changer for your sales team. This setup not only saves time but also increases the likelihood of converting leads into paying customers. Implementing this system will ensure that your team never misses a lead again.
By following these steps and utilizing Pabbly Connect, you can enhance your sales process and improve customer engagement effectively.
