To begin integrating Facebook Lead Ads with HubSpot, first access Pabbly Connect. Visit the Pabbly website and log in to your account. If you are a new user, you can sign up for free to explore the features available.
Once logged in, navigate to the dashboard. Here, you will find the option to create a new workflow. This is where you will set up the integration between Facebook Lead Ads and HubSpot, automating lead management seamlessly.
In your Pabbly Connect dashboard, click on ‘Create from Scratch’ to start a new workflow. Give your workflow a name that reflects its purpose, such as “Facebook Leads to HubSpot”. Then, select the appropriate folder for your workflow.
  • Choose a descriptive name for your workflow.
  • Select the folder where you want to save it.
  • Click on ‘Create’ to finalize the setup.
After creating the workflow, you will see two boxes for the trigger and action. The trigger will initiate the workflow whenever a new lead is generated from Facebook Lead Ads.
3. Setting Up Facebook Lead Ads Trigger
To set up the trigger, select Facebook Lead Ads as your trigger application in Pabbly Connect. Choose the event ‘New Lead Instant’ to ensure that the workflow activates whenever a new lead is captured. Click on ‘Connect’ to establish the connection.
If you do not have an existing connection, you will need to create a new one. Log in to your Facebook account to allow Pabbly Connect to access your Lead Ads. After successful login, select the page and lead form you want to connect.
  • Select the Facebook page associated with your Lead Ads.
  • Choose the specific lead form you want to use.
  • Click ‘Save and Send Test Request’ to verify the connection.
Once the connection is verified, you will receive a response from Facebook Lead Ads, confirming that the setup is successful. This response will be used to map the data into HubSpot.
4. Adding HubSpot as the Action Application
After setting up the trigger, the next step is to add HubSpot as the action application in Pabbly Connect. Select HubSpot and choose the event ‘Create a Contact’. This will allow you to automatically add new leads as contacts in your HubSpot CRM.
Similar to the previous step, click on ‘Connect’ to create a connection with HubSpot. If you have an existing connection, you can proceed by saving it. Otherwise, log in to your HubSpot account to establish the connection.
  • Log in to your HubSpot account to authorize the connection.
  • Map the fields from the Facebook Lead Ads response to HubSpot contact fields.
  • Click ‘Save and Send Test Request’ to finalize the setup.
After saving, check your HubSpot account to see if the new contact has been created successfully. This confirms that the integration between Facebook Lead Ads and HubSpot via Pabbly Connect is functioning correctly.
5. Conclusion
In this tutorial, we explored how to integrate Facebook Lead Ads with HubSpot using Pabbly Connect. This automation allows you to manage your leads efficiently without manual tracking. By following the steps outlined, you can easily set up this integration and streamline your lead management process.
Utilizing Pabbly Connect not only simplifies your workflow but also enhances your overall productivity. Start automating your lead management today!
