To start integrating applications like Gemini and Google Docs, you need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This is where you can sign up or log in to your existing account.
If you’re new, click on ‘sign up for free’ to receive 100 free tasks each month. Existing users can simply sign in. Once logged in, select the option to access Pabbly Connect and navigate to the dashboard to begin creating workflows.
After accessing Pabbly Connect, you will need to create a new workflow. Click on ‘Create from Scratch’ to start building your automation. This workflow will connect your AI tool, Gemini, with Google Docs.
  • Select the ‘Schedule’ trigger to set when the workflow should run.
  • Choose your desired days for the automation to trigger.
  • Set the time for execution, such as 10:00 AM.
Once configured, click ‘Save’ to finalize your trigger settings. You will see a confirmation message indicating that the trigger has been successfully set up in Pabbly Connect.
3. Generating Video Scripts Using Gemini
Next, you will configure Pabbly Connect to generate video scripts using Gemini. This involves connecting to your AI tool and setting up the necessary API key. Click on ‘Build New Connection’ and follow the prompts to enter your API key.
Once connected, provide a relevant prompt for Gemini to generate the video script. Make sure to select the appropriate model and method for content generation. Click ‘Save and Send Test Request’ to ensure everything is working correctly.
4. Creating a Google Doc for the Video Script
After generating the video script, the next step is to create a new document in Google Docs. In Pabbly Connect, click on ‘Build New Connection’ to link your Google account.
  • Select your Google account and grant access to Pabbly Connect.
  • Specify the document name, such as ‘Video Script for [Date]’.
  • Use the Date Time Formatter to automatically add the current date.
After creating the document, you will receive a confirmation indicating that the new Google Doc has been successfully created.
5. Adding the Generated Script to Google Docs
The final step is to insert the generated video script into the newly created Google Doc. In Pabbly Connect, select the previously connected Google Docs account to add the script.
Map the document ID received from the previous steps and insert the generated script text. Click ‘Save and Send Test Request’ to finalize this action. A successful response will confirm that the video script has been added to your Google Doc.
In this tutorial, we explored how to automate video script creation using Pabbly Connect, Gemini, and Google Docs. By following these steps, you can streamline your content creation process effectively.
