To automate your WordPress posts to Instagram, you first need to access Pabbly Connect. Open a new tab and type the URL pabbly.com/connect. This will take you to the Pabbly Connect homepage.
If you’re a new user, click on the “Sign Up Free” button to create an account. Existing users can simply click “Sign In”. Pabbly Connect offers 100 free tasks every month for new users, allowing you to explore its features without commitment.
2. Setting Up Your Workflow in Pabbly Connect
Once logged in, navigate to the workflow page of Pabbly Connect. Here, you can create a new automation workflow. The first step is to set a trigger, which in this case is the creation of a new post in WordPress.
- Select “WordPress” as your trigger application.
- Choose “New Post Published” as the event.
- Click the “Connect” button to generate a webhook URL.
Copy this webhook URL, as it acts as a bridge between WordPress and Pabbly Connect. You will need this URL in the next steps to link your WordPress account.
3. Integrating WordPress with Pabbly Connect
To complete the integration, go to your WordPress dashboard. Navigate to the “Plugins” section and click on “Add New”. Search for the plugin “WP Webhooks” and install it. This plugin allows you to send data from WordPress to Pabbly Connect.
After installation, go to the settings of the WP Webhooks plugin. Here, add the webhook URL you copied earlier. Set the trigger to “Post Created” and ensure the status is set to “Published”. Save your settings to finalize the integration.
4. Creating an Instagram Post Automatically
With the integration set up, it’s time to create a new post in WordPress. Go back to your WordPress dashboard and click on “Add New” under Posts. Fill in the title and description, upload an image, and click on “Publish”.
Once the post is published, Pabbly Connect will capture the data automatically. You can verify this by checking your Pabbly Connect dashboard, where it will indicate that it’s waiting for a webhook response.
- Ensure your post title and image URL are mapped correctly in Pabbly Connect.
- Select “Instagram for Business” as your action app.
- Choose “Create and Publish Photo” as the action event.
Map the fields from your WordPress post to Instagram, including the photo URL and post title. This mapping ensures that data flows correctly between applications.
5. Verifying the Integration with Instagram
After setting up the action in Pabbly Connect, click on “Save and Send Test Request”. This will send the data to your Instagram account. You should see a confirmation message indicating that the post has been successfully created.
Go to your Instagram account and refresh the page. You should see the new post, complete with the title and link to your WordPress post. This confirms that the integration is working seamlessly, allowing you to automate your social media presence.
By integrating WordPress and Instagram through Pabbly Connect, you can automate your posting process effectively. This not only saves time but also enhances your business’s online presence. Start using Pabbly Connect today to streamline your social media automation.
