To integrate WhatsApp with Pabbly Connect, first, you need to access the Pabbly Connect platform. This integration allows you to create an AI assistant that handles customer queries effectively.
To get started, visit the Pabbly Connect website and log in to your account. If you don’t have an account, sign up for one. Once logged in, navigate to the dashboard where you will find various options to create your automation.
2. Setting Up Your WhatsApp Number in Pabbly Connect
Before you can create an AI assistant, you must set up your WhatsApp number in Pabbly Connect. This step is crucial as it links your WhatsApp with the Pabbly platform, enabling automated responses.
  • Log in to your Pabbly Connect account.
  • Go to the settings and select “WhatsApp Integration”.
  • Enter your WhatsApp number and verify it.
By completing these steps, your WhatsApp number will be successfully integrated with Pabbly Connect, allowing for seamless communication with your AI assistant.
3. Creating Your AI Assistant in Pabbly Connect
With your WhatsApp number set up, you can now create your AI assistant. This assistant will respond to customer queries automatically, enhancing your business’s customer service.
To create an assistant, navigate to the “Assistant” section on the Pabbly Connect dashboard. Click on “Create Assistant” and fill in the required details, such as the assistant’s name. Select the type of assistant you want, like a customer support agent.
  • Choose the type of assistant: AI agent, customer support agent, etc.
  • Set the AI configuration, including temperature settings for response creativity.
  • Configure the AI provider, selecting OpenAI for advanced responses.
After filling in these details, save your assistant. This will enable it to start responding to queries on WhatsApp.
4. Training Your AI Assistant with Knowledge Sources
To ensure your AI assistant provides accurate responses, you need to train it using knowledge sources. This involves uploading a document that contains all relevant information about your business.
Create a comprehensive document that describes your business, including policies, products, and prices. Once your document is ready, upload it in the knowledge source section of Pabbly Connect. This will allow the assistant to generate informed responses based on the data you provide.
  • Upload a detailed document about your business.
  • Ensure the document covers FAQs and product details.
  • Train your assistant to respond accurately based on this information.
After uploading the document, your AI assistant will be better equipped to handle various customer queries effectively.
5. Activating and Testing Your AI Assistant
Once your AI assistant is set up and trained, it’s time to activate and test it. This step ensures that the assistant functions correctly and provides accurate responses to customers.
To activate your assistant, toggle the activation switch in Pabbly Connect. After activation, conduct a few test queries through WhatsApp to see how the assistant responds. You can ask questions like, ‘How do I place an order?’ or ‘What are your return policies?’
Make adjustments if necessary, based on the responses you receive during testing. This will help refine the assistant’s performance and improve customer interactions.
In conclusion, integrating WhatsApp with Pabbly Connect allows you to create an efficient AI assistant for your business. By following these steps, you can enhance customer service and streamline communication effectively.
