To start using Pabbly Connect for WhatsApp integration, you first need to access the platform. Simply visit the Pabbly website and search for Pabbly Connect. If you are a new user, click on the “Sign Up Free” button to create an account.
For existing users, click on “Sign In” to access your dashboard. Once logged in, navigate to the Pabbly Connect option, where you can manage your integrations. This is where you will set up your WhatsApp messaging process.
2. Setting Up WhatsApp in Pabbly Connect
Once you are in Pabbly Connect, the next step is to connect your WhatsApp account. You need to ensure that your WhatsApp number is linked. If you haven’t done this yet, check for tutorials on how to connect your WhatsApp number in the Pabbly dashboard.
  • Navigate to the “Integrations” section.
  • Select WhatsApp from the list of applications.
  • Follow the prompts to link your WhatsApp account.
After connecting your WhatsApp, you will see your dashboard update with the integration status. This is crucial for sending bulk messages later.
3. Creating a WhatsApp Message Template in Pabbly Connect
In this section, you will create a message template using Pabbly Connect. This template is essential for sending bulk WhatsApp messages efficiently. Navigate to the template section in your Pabbly dashboard.
Here, you can create a new template by entering your message details. Make sure to include variables such as recipient names to personalize each message. Once completed, submit the template for approval.
4. Sending Bulk WhatsApp Messages Using Pabbly Connect
To send bulk messages through Pabbly Connect, go to the Broadcast section. Here, you can add a new broadcast campaign. Select the type of broadcast, and give it a name like “Offers”.
  • Choose your audience from existing contacts or upload a CSV file.
  • Select the message type – either a pre-approved template or a regular message.
  • Test the message by sending it to your own WhatsApp number.
Once everything is set, you can schedule or send the broadcast immediately. This functionality allows you to reach multiple contacts without creating a WhatsApp group.
5. Monitoring the Results of Your Broadcast
After sending your broadcast with Pabbly Connect, you can monitor the results directly from the dashboard. You will see how many messages were sent, delivered, and any failures that occurred.
This data is crucial for assessing the effectiveness of your campaign. You can also reschedule broadcasts for any failed contacts easily from the same interface. This feature streamlines your communication process and ensures all messages are delivered effectively.
Using Pabbly Connect, you can seamlessly integrate WhatsApp for bulk messaging, making it easier to communicate with your contacts. This method saves time and enhances your outreach efforts effectively.
