1. Introduction to Sending Bulk WhatsApp Messages with Pabbly Connect
In this tutorial, we will explore how to send bulk WhatsApp messages using Pabbly Connect. This powerful integration platform allows you to connect Google Sheets with WhatsApp seamlessly. By the end of this guide, you will be able to send promotional messages to multiple contacts efficiently.
To start, ensure you have a Google Sheet with all your customer data. This sheet will act as the source from which Pabbly Connect will pull information to send messages. With the right setup, you can automate the process of messaging hundreds of clients in just a few clicks.
2. Setting Up Google Sheets with Pabbly Connect Webhooks
The first step in our process is to connect Google Sheets with Pabbly Connect. This involves using the Pabbly Connect Webhooks feature, which allows us to capture data from our sheet. To do this, you will need to copy the webhook URL provided by Pabbly Connect into your Google Sheets.
  • Open your Google Sheet and navigate to Extensions.
  • Select Add-ons and search for ‘Pabbly Connect Webhooks’ to install it.
  • After installation, refresh the spreadsheet to see the Pabbly Connect Webhooks option.
Once the add-on is installed, go to the Initial Setup option, paste the webhook URL into the designated field, and select the last data column to send. This setup ensures that every time you add a new contact, Pabbly Connect will capture the data and trigger the messaging process.
3. Configuring the Webhook to Capture Data
After setting up the webhook, it’s crucial to configure it correctly to ensure data is captured effectively. You’ll need to specify the trigger column, which indicates when the data should be sent to Pabbly Connect.
To complete this configuration, follow these steps:
  • Access the Initial Setup dialog and paste the webhook URL.
  • Specify the trigger column (e.g., Column D) where your data ends.
  • Click Submit to save the configuration.
Now, every time you input a new customer’s data into the spreadsheet, Pabbly Connect will automatically trigger the sending of WhatsApp messages based on the captured data.
With the webhook configured, the next step is to send WhatsApp messages. You will need to select a WhatsApp management tool, and for this tutorial, we will use Pabbly Chatflow. This tool integrates seamlessly with Pabbly Connect to facilitate messaging.
To send messages, follow these steps:
  • Log into your Pabbly Chatflow account and navigate to the API settings.
  • Generate an API token and paste it into the appropriate field in Pabbly Connect.
  • Map the phone number and message fields from your Google Sheet to the corresponding fields in Pabbly Connect.
Once everything is set up, you can send test messages to ensure that the integration is working correctly. This process allows you to send personalized messages to each contact listed in your Google Sheet.
5. Testing and Finalizing Your Bulk Messaging Setup
The final step is testing your setup to ensure everything works as expected. After mapping all necessary fields in Pabbly Connect, you can send a test message to verify the connection.
To test, simply click the “Send Test” button in Pabbly Connect. If successful, you will receive a confirmation message indicating that the data has been sent. This confirms that your integration is functional and ready for bulk messaging.
Once testing is complete, you can start sending bulk messages to all your contacts in the Google Sheet. This automated process will save you time and effort, allowing you to focus on other business tasks.
In conclusion, using Pabbly Connect to send bulk WhatsApp messages is an efficient way to manage customer communications. By integrating Google Sheets with WhatsApp through Pabbly Connect, you can automate the messaging process effectively, ensuring timely and personalized communication with your clients.
