1. Accessing Pabbly Connect for Your Chatbot
To create a WhatsApp appointment booking chatbot, the first step is accessing Pabbly Connect. Start by visiting the Pabbly website and navigate to the Pabbly Chat Flow section.
Once there, create your account if you are not a user yet. After signing up, head to the flow builder of Pabbly Connect where you can design your chatbot flow easily. This intuitive interface allows you to set up various triggers and actions.
2. Setting Up Trigger Events in Pabbly Connect
Next, you need to set up a trigger event in Pabbly Connect. A trigger event is essential as it starts the chatbot flow. For this, select the keyword trigger option.
- Choose keywords like “Hello”, “Hi”, and “Book Appointment”.
- Enter each keyword and press enter to add them.
- These keywords will trigger the chatbot whenever a user sends them.
By setting these keywords, whenever a user sends any of them on WhatsApp, the chatbot will automatically respond with a welcome message, initiating the interaction.
3. Creating a Welcome Message in Pabbly Chat Flow
After setting up the trigger, the next step in Pabbly Connect is to create a welcome message. This message is what users will see when they trigger the chatbot.
To do this, add a text button and customize the message. You can include quick buttons like “Book Appointment” and “Contact Us” for user convenience. This way, your customers can easily navigate through the options provided by your chatbot.
- Customize the welcome message to make it engaging.
- Ensure the quick buttons are clearly labeled for easy access.
Once the welcome message is set, connect the trigger node to the text button to ensure seamless communication with your users.
4. Sending List Messages for Appointment Options
When a user clicks on the “Book Appointment” button, you need to send them a list of appointment options. This is where Pabbly Connect shines by allowing you to add a list node.
In the list node, write the message and add multiple options for users to choose from. You can provide various consultation types based on your services.
- Add a header and footer if needed.
- Use the “Add Section” button to create different categories.
Once the list is prepared, connect it back to the previous node to maintain the flow of conversation within the chatbot.
5. Personalizing Messages with Custom Fields
The final step in your chatbot setup using Pabbly Connect is to personalize messages using custom fields. This will enhance user experience by making interactions more relevant.
When a user selects a consultation type, the chatbot should ask for their name and contact number. You can add a question node for this purpose.
- Set the format for the input (e.g., text).
- Specify the number of attempts a user can make to provide their details.
Using this method, when users share their information, the chatbot can send a personalized confirmation message, making the interaction feel more tailored and engaging.
In this tutorial, you learned how to create a WhatsApp appointment booking chatbot using Pabbly Connect and Pabbly Chat Flow. This step-by-step guide simplifies the process, enabling efficient customer interactions.
