To start sending bulk WhatsApp messages, first, you need to access Pabbly Chatflow. Open a new tab in your browser and navigate to pabbl.com/chatflow. This platform provides the official WhatsApp Business Cloud API, ensuring a lower chance of your number getting blocked.
Once on the landing page, you can sign up for a free trial of Pabbly Chatflow. This trial allows you to test the features before committing to a subscription. After signing up, you can explore the dashboard and begin the integration process.
2. Adding Your WhatsApp Number to Pabbly Chatflow
Before sending messages, you must add your WhatsApp number in Pabbly Chatflow. Ensure that you follow the video tutorial linked in the description to complete this step. This is crucial for the integration to work smoothly.
After adding your number, navigate to the left sidebar and select the “Broadcast” section. Here, click on the “Add Broadcast” button. You will need to name your broadcast and choose the type as “Broadcast Campaign”. For instance, you can name it “New Offers”.
3. Uploading CSV Files for Audience Selection
In this step, Pabbly Chatflow allows you to upload a CSV file containing the contacts you want to message. Click on “Upload CSV File” and select your file. If you have already created a contact list within Pabbly Chatflow, you can select it from the options provided.
  • Upload your CSV file containing contact details.
  • Select an existing contact list if available.
  • Optionally exclude contacts from the broadcast.
Once your audience is selected, you can proceed to the next step in Pabbly Chatflow to customize your message.
4. Selecting Message Type in Pabbly Chatflow
Next, you need to choose the type of message you want to send through Pabbly Chatflow. You can select either a pre-approved template message or a regular message. If you choose a regular message, simply enter your message in the provided field.
If you opt for a pre-approved template, navigate to the “Template” section in the left sidebar. Here you can create a template that needs to be approved by Meta before use. Once approved, select your template and make sure to include dynamic fields like “dollar name” to personalize your messages.
5. Sending Your Broadcast Messages via Pabbly Chatflow
After setting up your message, you can test it by sending it to yourself. Enter your WhatsApp name and mobile number, and click on the “Send Message” button to verify that everything works correctly. Once confirmed, you can send the message to all your contacts.
  • Click on “No Send Instantly” to schedule the broadcast.
  • Choose a date and time from the calendar for scheduling.
  • Select retry options for failed messages.
Once your broadcast is scheduled, you can view the stats in the “Send” section of Pabbly Chatflow. This includes data on sent, delivered, and read messages, allowing you to track the effectiveness of your campaign.
In this tutorial, we explored how to send bulk WhatsApp messages using Pabbly Chatflow. By following these steps, you can streamline your messaging process and engage your audience effectively. Take advantage of Pabbly Chatflow’s features to enhance your communication strategy.
