To start using Pabbly Connect for integrating WhatsApp leads into your CRM, first visit the Pabbly website at pably.com. You can sign up for a free account if you’re a new user or log in if you’re already registered.
Once logged in, navigate to your dashboard and select Pabbly Connect to begin creating your automation workflow. This platform will allow you to connect WhatsApp with your CRM seamlessly.
In your Pabbly Connect dashboard, click on “Create Workflow”. Name your workflow something like “WhatsApp Leads to CRM Contacts” and select the appropriate folder for organization.
This step is crucial as it sets the foundation for your automation. After naming, click on “Create” to proceed. Your workflow is now ready to have triggers and actions added.
- Click on “Add Trigger”.
- Select WhatsApp Cloud API as the trigger application.
- Choose the “Message Notification” event.
With these steps, you’ve successfully set up the trigger that will initiate your workflow whenever a new message arrives on WhatsApp.
3. Setting Up Webhook for WhatsApp
After creating your trigger, Pabbly Connect will provide you with a Webhook URL. Copy this URL to configure it in the Meta Developers section of your WhatsApp API settings.
Go to the Meta Developers page, select your app, and navigate to the “WhatsApp” settings. Here, you will find the option to configure your Webhook. Paste the URL you copied from Pabbly Connect and enter the verification token provided by Pabbly.
- Remove any existing Webhook URLs.
- Save and verify the Webhook settings.
- Test the connection by sending a message to your WhatsApp number.
Once verified, your WhatsApp messages will start triggering actions in Pabbly Connect automatically.
4. Adding Action Step to Create CRM Contacts
Next, you will add an action step in Pabbly Connect to create a new contact in your CRM. Choose Salesforce as the action application and select the “Create Contact” action event.
Connect your Salesforce account to Pabbly Connect, allowing it to create contacts based on the WhatsApp messages received. Map the necessary fields like first name, last name, and phone number from the incoming WhatsApp message.
- Enter the first name and last name as received.
- Map the phone number from the WhatsApp message.
- Add any additional details like email or message content.
Once all details are mapped, save the action step. This ensures that every new WhatsApp message creates a corresponding contact in your CRM.
5. Testing the Integration
Finally, test your integration to ensure everything works smoothly. Send a test message via WhatsApp to your connected number. Check the Pabbly Connect workflow for any incoming data from WhatsApp.
If the test is successful, you should see the WhatsApp message details reflected in your CRM as a new contact. This confirms that your integration is functioning correctly.
In case of any issues, review the mapping and Webhook settings in Pabbly Connect. Ensure that all configurations are correct and try testing again.
Using Pabbly Connect, you can easily automate the process of adding WhatsApp leads to your CRM. This integration streamlines your workflow and enhances your business efficiency.
Follow the steps outlined in this tutorial to set up your own automation and experience the benefits of seamless integration.
