1. Creating a WhatsApp Chatbot with Are and Paby
Creating a WhatsApp chatbot with Paby is essential for automating customer interactions. This chatbot will handle travel package inquiries effectively, enhancing user experience.
To start, send a message such as ‘hello’ to initiate the chatbot. The bot responds with a welcome message and a button labeled ‘Travel Packages’. This interaction showcases the power of integrating Are and Paby.
2. Setting Up Paby for Integration
To set up Paby, navigate to the flow page. If you are a new user, visit the URL paby.com/chatflow to sign up. Existing users can sign in directly.
Once on the flow page, configure your WhatsApp number. This is crucial for the chatbot to function properly. Here’s how to do it:
- Open the Paby Chatflow interface.
- Add your WhatsApp number in the settings.
- Save your changes to enable the chatbot.
After saving, your WhatsApp number will be linked to Paby, allowing seamless communication.
3. Designing the Chatbot Flow with Are and Paby
Designing the chatbot flow in Paby involves setting triggers and responses. The trigger can be a keyword like ‘hello’. This keyword initiates the chatbot’s response.
To set this up, drag and drop the message blocks into the flow. Create a welcome message and add a button for ‘Travel Packages’. The flow should look like this:
- Drag the text button into the flow.
- Set the button type to quick reply.
- Connect the button to the list of travel packages.
This setup allows users to select their desired package easily.
4. Adding Package Details in Paby
Adding package details is a crucial step in the integration of Are and Paby. After the user selects a package, provide detailed information about it.
For example, when a user selects the ‘Goa Getaway’, the chatbot should display:
- Package details including pricing.
- A button to book the package.
- Follow-up questions for travel dates and customer details.
This ensures that users receive all necessary information to proceed with their booking.
Finalizing the integration involves saving your flow and testing the chatbot. Ensure that all components are functioning as intended.
To test, send a message to your WhatsApp number and check the responses. Make sure the chatbot accurately captures user inputs like travel dates and names. This step is crucial for ensuring a smooth user experience. Once everything is verified, you can launch your WhatsApp chatbot.
Integrating Are with Paby using Make allows travel agencies to automate their WhatsApp interactions efficiently. By following this tutorial, you can create a functional chatbot that enhances customer engagement and streamlines booking processes.
