To start integrating WhatsApp with Pabbly Connect, first, access your Pabbly Connect account. This platform serves as the backbone for all your integrations, enabling seamless communication between WhatsApp and other applications.
To create your integration, visit the Pabbly Connect dashboard. If you don’t have an account, you can sign up for free and explore the features offered. Once logged in, you can begin setting up your workflow.
2. Setting Up Your WhatsApp Chatbot with Pabbly Chatflow
Next, you need to set up your WhatsApp chatbot using Pabbly Chatflow. Begin by navigating to the Chatflow dashboard where you can add your WhatsApp number. This step is essential for enabling your chatbot to interact with customers effectively.
- Click on the ‘Add WhatsApp Number’ button.
- Choose a method to link your WhatsApp account.
- Confirm the integration to start using the chatbot features.
Once your WhatsApp number is integrated, you can begin creating flows for your chatbot. This is where you can set the triggers and responses that will guide customer interactions.
3. Creating Chatbot Flows in Pabbly Chatflow
Creating flows in Pabbly Chatflow allows you to design how your chatbot will interact with users. Start by selecting the ‘Flows’ option from the dashboard. Here, you can add a new flow for your travel agency chatbot.
In the flow builder, define the trigger event that will initiate the chatbot. For instance, you can set the trigger to activate when a user sends a specific keyword like “travel”. This keyword will prompt the chatbot to respond with a welcome message and begin the inquiry process.
- Select ‘Add Flow’ to create a new flow.
- Choose ‘Keyword’ as the trigger type.
- Define the keyword that will trigger the chatbot.
After setting up the trigger, you can design the welcome message that will greet users and guide them through the inquiry process.
4. Collecting User Information through Pabbly Connect
Once the chatbot is set up, it’s time to collect user information. This is where Pabbly Connect plays a crucial role in storing the data. As users interact with the chatbot, their responses will be captured and sent to Pabbly Connect for processing.
To do this, you will need to add an API request within your flow. This step involves configuring the API to send user responses directly to your Pabbly Connect account. Ensure you set the request type to POST and provide the necessary webhook URL from your Pabbly Connect dashboard.
- Open your Pabbly Connect account and create a new workflow.
- Copy the webhook URL provided.
- Paste the webhook URL into the API request settings in Pabbly Chatflow.
With this setup, every response collected by your chatbot will be sent to Pabbly Connect, allowing you to manage and analyze customer data efficiently.
5. Finalizing Your Integration and Testing
After configuring the API request, finalize your integration by ensuring all connections are properly established. In Pabbly Connect, save the workflow and test the chatbot to verify that it functions correctly.
To test the setup, send the trigger keyword through your WhatsApp account. The chatbot should respond with a welcome message and proceed to collect the necessary travel details. If everything works as expected, your integration is complete.
- Send the trigger keyword to your WhatsApp chatbot.
- Observe the chatbot’s response and ensure it collects user data.
- Check Pabbly Connect to confirm data has been recorded.
With successful testing, you can now utilize your WhatsApp chatbot to enhance customer experience and streamline travel inquiries using Pabbly Connect and Pabbly Chatflow.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect and Pabbly Chatflow to automate travel inquiries. By following these steps, you can create an efficient chatbot that enhances customer interactions and simplifies the booking process.
