To start integrating WhatsApp with Pabbly Connect, first, access the Pabbly Connect dashboard. This platform is essential for setting up your automation process. Once logged in, you can create a new workflow to automate WhatsApp interactions.
Begin by selecting the option to create a new workflow. You will be prompted to name your workflow. For instance, you can name it “WhatsApp Gym Chatbot” to reflect its purpose. This step is crucial as it helps you keep track of your various automations.
2. Setting Up the WhatsApp Trigger in Pabbly Connect
Now that you have created your workflow, it’s time to set up the trigger for WhatsApp. The trigger is what initiates the automation when a user sends a message. In this case, you will set the trigger to activate when a specific keyword, such as “hello”, is received via WhatsApp.
- Select the “Webhook” option in Pabbly Connect.
- Copy the Webhook URL provided.
- Go to your WhatsApp settings and configure the Webhook URL.
After setting up the Webhook, you can test it by sending a message to your WhatsApp number. This will confirm that the trigger is working correctly and is ready to initiate the automation.
3. Creating the WhatsApp Chatbot Flow with Pabbly Connect
With the trigger set, you can now design the chatbot flow using Pabbly Connect. This involves creating a welcome message and options for users to book classes or ask questions. Start by dragging and dropping message blocks into your flow.
For the welcome message, you can type something like, “Welcome to our Gym! Please choose an option below:”. Then, create buttons for the options: “Book Fitness Classes” and “Ask Questions”. Each button will lead to different paths in your automation.
- For the “Book Fitness Classes” button, add a message block that lists available classes.
- For the “Ask Questions” button, connect it to your AI assistant.
This structure allows users to navigate easily and get the information they need without leaving WhatsApp, making the process efficient.
4. Collecting User Information for Class Bookings
When users select the “Book Fitness Classes” button, you can prompt them to enter their details. This is where Pabbly Connect shines by allowing you to collect user inputs seamlessly. Ask for their full name and preferred class timings.
For example, after the user selects a class like Yoga, you can ask them to enter their full name and preferred timing. Use input fields to collect this information and store it using Pabbly Connect’s custom fields feature.
- Create custom fields for “Full Name” and “Preferred Timing”.
- Ensure that responses are stored correctly for personalized confirmation messages.
Once the user provides their information, send a confirmation message thanking them and confirming their booking. This enhances user experience and builds trust.
5. Integrating AI Assistant for Queries in Pabbly Connect
To enhance the user experience further, integrate an AI assistant into your WhatsApp chatbot using Pabbly Connect. This assistant can handle queries related to gym membership plans and other questions users may have.
When a user selects the “Ask Questions” button, trigger the AI assistant to respond based on a pre-defined knowledge base. This allows users to get instant answers without waiting for human interaction.
- Set up the AI assistant with relevant information about your gym.
- Ensure the assistant can answer common questions accurately.
This integration not only saves time for your staff but also provides a quick service to your clients, enhancing overall satisfaction.
Integrating WhatsApp with Pabbly Connect allows gym owners to automate class bookings and answer queries efficiently. This setup enhances customer interaction and streamlines operations, making it a valuable tool for any business.
