To start integrating your WhatsApp chatbot, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly website and signing up or logging in to your account. Once you are in, navigate to the Pabbly Connect dashboard where you can create new workflows.
Creating a new workflow in Pabbly Connect is straightforward. Click on the “Create Workflow” button, name your workflow, and select WhatsApp as your trigger application. This setup will allow you to automate responses to customer inquiries effectively.
2. Setting Up Your WhatsApp Chatbot with Pabbly Connect
Once you have accessed Pabbly Connect, it’s time to set up your WhatsApp chatbot. Begin by selecting the trigger event, which will initiate your chatbot. For example, you can set a keyword like “hello” to trigger the chatbot when users send this message.
  • Choose WhatsApp as the trigger application.
  • Set the trigger event to a keyword match.
  • Enter your trigger keyword, such as “hello”.
After setting the trigger, you can start configuring the chatbot’s responses. This includes asking users for their names and the type of event they are planning. This interaction will help gather necessary information for your service.
3. Creating the Chatbot Flow in Pabbly Connect
Next, you will create the flow of your WhatsApp chatbot within Pabbly Connect. This involves using action blocks to ask questions and gather user inputs. Start by adding a question node where you ask for the user’s full name.
To personalize responses, set up a contact custom field for the user’s name. You can do this by going to the settings and selecting “Contact Custom Fields”. Create a new field for the full name to store the user’s input.
  • Add a question node for user input.
  • Create a custom field for storing names.
  • Use action blocks to manage user interactions.
This setup allows your chatbot to respond dynamically based on user inputs, enhancing the overall user experience.
4. Finalizing Your WhatsApp Chatbot Configuration
After creating the initial flow, you need to finalize the configuration of your WhatsApp chatbot using Pabbly Connect. This includes setting up additional questions, such as the event date and how users would like to proceed with their planning.
Use text button nodes to provide users with options, like seeking planning help or contacting a planner. Assign actions to each button, ensuring that users receive appropriate responses based on their selections.
  • Add buttons for user choices.
  • Set actions for each button based on user input.
  • Ensure a smooth flow of conversation.
By finalizing these configurations, your WhatsApp chatbot will be ready to assist users effectively, providing them with the information they need.
5. Testing and Launching Your WhatsApp Chatbot
Once you have completed the setup of your WhatsApp chatbot in Pabbly Connect, it’s crucial to test the flow to ensure everything works as intended. Send test messages to see how the chatbot responds to various inputs.
After testing, you can launch your chatbot for public use. Make sure to save all changes in Pabbly Connect before going live. This will ensure that your chatbot is fully operational and ready to assist users with their event planning needs.
In this tutorial, we covered how to integrate a WhatsApp chatbot using Pabbly Connect. By following these steps, you can streamline customer interactions and provide valuable assistance in event planning.
