1. Accessing Pabbly Connect for WhatsApp Messaging
To begin using Pabbly Connect for WhatsApp bulk messaging, first navigate to Pabbly Connect by visiting pabbly.com/chatflow in your browser. This platform allows you to integrate various applications seamlessly, making it ideal for property launch promotions.
Once on the Pabbly Chat Flow homepage, you can either sign up for a free trial or log into your existing account. If you are a new user, click on the “Sign Up Free” button to get started. Pabbly Connect is essential for managing your WhatsApp messaging campaigns effectively.
2. Setting Up WhatsApp Chat Flow
After logging into your Pabbly account, select Pabbly Chat Flow from the applications menu. This will direct you to the Chat Flow dashboard where you can set up your WhatsApp number for messaging. Ensure that your WhatsApp number is linked correctly to enable bulk messaging.
Next, you will create a message template for your property launch promotion. This template will be used for your WhatsApp broadcast. Follow these steps to set up your template:
  • Go to the Templates section in Pabbly Chat Flow.
  • Create a new template and include relevant images and text.
  • Ensure your template is approved by Meta for use.
Now that your template is ready, you can proceed to the broadcasting section of Pabbly Connect.
3. Creating a WhatsApp Broadcast
With your message template set up, it’s time to create a WhatsApp broadcast using Pabbly Connect. Navigate to the broadcasting section in your Pabbly Chat Flow dashboard. Here, you will find options to create a new broadcast campaign.
To initiate a broadcast, click on the “Add Broadcast” button. You will be prompted to select the type of broadcast campaign you want to run. Choose “Broadcast Campaign” and name it something relevant, like “New Property Launch”. You can then select your audience from existing contact lists or upload a CSV file with new contacts.
4. Importing Contacts for Your Broadcast
To effectively use Pabbly Connect for your WhatsApp bulk messaging, you need to import your contacts. If you already have a list, select it from the options provided. Alternatively, you can upload a CSV file containing your contacts from Google Sheets or any other source.
Once your contacts are imported, you can refine your audience. Use the “Refine Audience” feature to exclude contacts you don’t want to send messages to. This ensures that your broadcast only reaches the intended recipients, enhancing the effectiveness of your property launch promotion.
5. Scheduling and Sending Your WhatsApp Broadcast
After setting up your audience, it’s time to schedule the broadcast in Pabbly Connect. You can choose to send the messages immediately or schedule them for a later date. If you opt for scheduling, ensure you select a future date and time.
Additionally, Pabbly Connect allows you to set up automatic retries for failed messages. This feature ensures that your broadcast reaches all valid contacts. Once everything is configured, click on “Create Broadcast” to finalize your setup. You will receive a confirmation that your broadcast has been scheduled successfully.
In summary, using Pabbly Connect for WhatsApp bulk messaging can significantly streamline your property launch promotions. By following the steps outlined, you can efficiently create and manage your messaging campaigns, ensuring that your audience receives timely updates.
