1. Accessing Pabbly Connect for WhatsApp Messaging
To start using Pabbly Connect for sending bulk WhatsApp messages, first, navigate to pabbly.com/chatflow in your browser. This will take you to the Pabbly Chatbot homepage.
If you are a new user, click on “Sign Up Free” to create your account. For existing users, simply log in. Once logged in, you can access the features that enable mass messaging through WhatsApp.
2. Setting Up Pabbly Chatbot for Bulk Messaging
After accessing Pabbly Connect, select Pabbly Chatbot from the list of applications. You will need to link your WhatsApp number within your Chatbot account. If you need assistance with this, refer to the tutorial available on the Pabbly YouTube channel.
Once your WhatsApp number is linked, you can create a message template. This involves navigating to the templates section within Pabbly Chatbot. Here, you can see approved templates, drafts, and rejected messages. Make sure your template is approved by Meta to ensure compliance.
  • Navigate to the templates section.
  • Create a new template with a promotional message.
  • Ensure the template is approved by Meta.
With your template in place, you can move on to setting up the broadcast feature for sending messages to your contacts.
3. Creating a Broadcast in Pabbly Connect
To initiate a broadcast, go to the broadcast section in Pabbly Chatbot. Here, you will create a new broadcast by naming it appropriately, such as “New Promotional Offer”. Choose the audience for your broadcast, which can be an existing contact list or a CSV file.
If you opt for a CSV file, ensure you download your Google Sheet data as a CSV first. After uploading, click on the import button to create a separate contact list. You can also refine your audience by excluding specific contacts if necessary.
  • Name your broadcast, e.g., “New Promotional Offer”.
  • Select your audience from existing contacts or upload a CSV file.
  • Optionally refine your audience by excluding specific contacts.
Once your audience is set, you can proceed to select the type of message and schedule the broadcast.
4. Scheduling Broadcast Messages with Pabbly Connect
After selecting your audience, you can choose the type of message you want to send. If you have an approved template, select that option. You can also customize your message further by adding variables for personalization.
Before sending your broadcast, it’s crucial to test the message. Send a test message to your own WhatsApp number to ensure everything appears correctly. Once satisfied, you can schedule the broadcast for immediate sending or set a future date and time.
To schedule, select a future date and time, ensuring it is in the future to avoid immediate sending. You can also set automatic retries for failed messages by enabling this option.
5. Monitoring Broadcast Results in Pabbly Connect
Once your broadcast is sent, you can monitor its performance through the statistics section in Pabbly Chatbot. Here, you will find data on sent, delivered, read, and failed messages. This information is crucial for analyzing the effectiveness of your promotional campaigns.
If necessary, you can resend messages to contacts who did not receive them successfully. This feature enhances your outreach efforts and ensures your messages reach as many customers as possible.
In conclusion, using Pabbly Connect to send bulk WhatsApp messages for e-commerce promotions is a straightforward process. By following these steps, you can effectively reach your audience and boost your sales during promotional events like Black Friday.
In summary, this tutorial demonstrated how to utilize Pabbly Connect for mass WhatsApp messaging, focusing on setup, broadcasting, and monitoring results. Implement these steps to enhance your e-commerce promotions effectively.
