To start sending bulk WhatsApp messages, you’ll first need to access Pabbly Connect. This platform allows you to connect various applications seamlessly, making your workflow efficient.
Begin by visiting the Pabbly website and signing in to your account. If you’re new, you can sign up for a free trial. Once logged in, navigate to the Pabbly Connect dashboard where you’ll find all available applications.
2. Setting Up Pabi Chatflow with Pabbly Connect
In this section, you’ll set up Pabi Chatflow, the all-in-one WhatsApp communication platform. This integration is crucial for sending personalized messages to your customers.
- Go to pabyt.com/chatflow and sign in or sign up.
- Once in your dashboard, click on “Access Now” for Pabi Chatflow.
- Connect your WhatsApp number by clicking the “Add” button.
After connecting your WhatsApp number, you can create templates for your messages. This setup is essential for sending bulk messages effectively through Pabbly Connect.
3. Creating WhatsApp Message Templates
To send personalized messages, you’ll need to create a WhatsApp message template. This is where you can include variables like customer names to make your communications more engaging.
In Pabi Chatflow, navigate to the template section and click on “Add Template”. You can either create a new template or generate one using AI. After submitting your template, it will need approval before you can use it.
- Choose a name for your template, such as “New Arrivals Update”.
- Include dynamic variables for personalization, like customer names.
- Submit the template for approval to start using it.
Using Pabbly Connect, you can easily manage and track your message templates, ensuring they are ready for your broadcast.
4. Sending Broadcast Messages via Pabbly Connect
Once your template is approved, you can proceed to send broadcast messages. This is a straightforward process that will allow you to reach all your contacts efficiently.
In the Pabi Chatflow dashboard, select the “Broadcast” option and click on “Add Broadcast”. Here, you will name your broadcast and select the contact list to which you want to send messages. Ensure that your contacts are uploaded in CSV format for bulk messaging.
- Choose the type of message: pre-approved template or regular message.
- Select your approved template for sending.
- Test your broadcast by sending a message to your own number first.
Utilizing Pabbly Connect ensures that your messages are sent without any issues, allowing for a smooth communication process with your customers.
5. Scheduling Your WhatsApp Broadcasts
After testing your broadcast, you have the option to send messages immediately or schedule them for later. This feature allows you to plan your communications effectively.
To schedule your broadcast, select the date and time for when you want your messages to be sent. Make sure to choose a future date to avoid instant sending.
- Input the desired date and time in the scheduling section.
- Click on “Add Broadcast” to finalize your schedule.
- Review the broadcast stats after sending to track delivery status.
Using Pabbly Connect for scheduling ensures that your messages reach your audience at the right time, enhancing engagement and response rates.
In this tutorial, we explored how to use Pabbly Connect to send personalized bulk WhatsApp messages efficiently. By integrating Google Sheets and Pabi Chatflow, you can automate your communication effectively. Start using this powerful tool today for better customer engagement!
