1. Accessing Pabbly Connect for WhatsApp Broadcasts
To create a WhatsApp broadcast campaign, you first need to access Pabbly Connect. This platform serves as the central hub for integrating various applications like Pabbly Chatbot and CSV files.
Once you log into your Pabbly Connect account, navigate to the Pabbly Chat Flows section. Here, you can begin setting up your broadcast campaign, ensuring a smooth communication process with your audience.
2. Setting Up Your Broadcast Campaign in Pabbly Chat Flows
After accessing Pabbly Chat Flows, click on the ‘Add Broadcast’ button to start creating your campaign. This step is crucial as it allows you to define the type of broadcast you want to send.
  • Select the type of broadcast, typically labeled as ‘Broadcast Campaign’.
  • Enter a name for your broadcast, such as “New Viral Dance Promotion”.
  • Choose your audience by selecting either an existing contact list or uploading a CSV file.
This process is essential for reaching your target audience effectively. You can upload a CSV file containing customer details or select a pre-existing list from Pabbly Chatbot.
3. Choosing Your Audience and Message Type
Once you have set up your broadcast campaign, the next step is to choose your audience. You can either upload a CSV file or select a list from your existing contacts in Pabbly Chatbot.
After selecting your audience, you can refine your list by excluding certain contacts if necessary. This ensures that your message reaches the right people without redundancy.
  • Exclude contacts who should not receive the message.
  • Activate the option to skip contacts that messaged you in the last 24 hours.
These features enhance your targeting capabilities, making your broadcast more effective and reducing the chances of overwhelming your audience.
4. Crafting Your Message with Pabbly Connect
In this step, you will define the type of message you want to send through your broadcast campaign using Pabbly Connect. You can choose between a template message or a regular message.
For template messages, ensure that your templates are approved by Meta. This allows you to initiate conversations with your audience effectively. If you opt for a regular message, remember that it can only be sent if the chat window is active within the last 24 hours.
  • Select a WhatsApp template that fits your campaign.
  • Add images or other media to enhance your message.
This flexibility allows you to create engaging and visually appealing messages that resonate with your audience, increasing the likelihood of interaction.
5. Testing and Scheduling Your Broadcast Campaign
After crafting your message, it’s essential to test it before launching your broadcast. Use the test feature in Pabbly Connect to ensure everything works as expected.
Once testing is complete, you can schedule your broadcast. Choose a specific date and time for your message to go live, or send it immediately if you prefer.
  • Set a schedule for your broadcast, e.g., 26th October at 3:35 PM.
  • Enable automatic retries for any failed messages.
This ensures that your campaign reaches as many recipients as possible, and you can view the broadcast statistics later to assess its performance.
In conclusion, using Pabbly Connect to create WhatsApp broadcast campaigns is a streamlined process that allows you to engage effectively with your audience. By following these steps, you can ensure your messages are delivered successfully and on time, enhancing your marketing efforts.
