1. Accessing Pabbly Connect for WhatsApp Broadcast Automation
To start automating WhatsApp broadcasts, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/chatflow. This will direct you to the Pabbly Chat Flow homepage.
If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply sign in. Once logged in, go to the “All Pabbly Apps” section and select Pabbly Chat Flow by clicking on ‘Access Now’. This will take you to the dashboard where you can manage your WhatsApp communications.
2. Setting Up Your WhatsApp Broadcast Template
With Pabbly Connect, you can create a WhatsApp broadcast template that allows you to send messages in bulk. Start by navigating to the ‘Templates’ section within Pabbly Chat Flow. Here, you can view your approved, pending, draft, and rejected templates.
  • Select the approved template you want to use for your broadcast.
  • Ensure your template includes the message and any images you want to send.
  • Confirm that the template is approved by Meta to use it for broadcasts.
Once you have your template ready, proceed to the broadcast section to set up your WhatsApp broadcast campaign using Pabbly Connect.
3. Creating a WhatsApp Broadcast Campaign
In the broadcast section, click on the ‘Add Broadcast’ button to initiate a new campaign. Select the broadcast type as “Broadcast Campaign” and name it, for example, “New Cold Lead Message”. This naming helps in identifying the campaign later on.
Next, you will choose your audience. If you have an existing contact list, select it. Alternatively, if your contacts are stored in a Google Sheet, download the data as a CSV file to upload it here. Make sure to refine your audience by excluding contacts you do not wish to message. This can be done through the audience refinement options available in Pabbly Connect.
4. Sending and Testing Your Messages
Once your broadcast is set up, you can choose the message type. If you prefer to send a pre-approved template message, select it from the drop-down menu. You can also upload any media you want to include with your message.
  • Add any personalization variables if needed.
  • Test your broadcast message by sending it to your own WhatsApp number.
After testing, you can schedule the broadcast for immediate sending or choose a future date and time. Ensure you select a future date to avoid instant sending if that’s not your intention. Pabbly Connect allows you to automate retries for any failed messages, ensuring your broadcast reaches as many contacts as possible.
5. Tracking Results and Resending Broadcasts
Once your broadcast is sent, you can track its performance using Pabbly Connect. The dashboard provides statistics on sent, delivered, read, pending, and failed messages. This data is crucial for understanding the effectiveness of your campaign.
If some messages failed to deliver, you can resend them easily by selecting the resend option available in the broadcast section. This functionality ensures that all your contacts receive the important updates you wish to share via WhatsApp.
In this tutorial, we explored how to automate WhatsApp broadcasts using Pabbly Connect. By following these steps, you can efficiently reach more customers automatically, ensuring your messages are delivered effectively. Leverage the power of Pabbly Connect to enhance your communication strategy.
