To start automating WhatsApp broadcasts, you need to access Pabbly Connect. Open your browser and go to pabbly.com/chatflow. This will take you to the Pabbly Chat Flow homepage.
If you are a new user, click on “Sign Up Free” to create an account. Existing users can simply log in. Once logged in, you will have access to all Pabbly applications, including Pabbly Chat Flow.
2. Setting Up Pabbly Chat Flow for WhatsApp Broadcasts
In this section, you will learn how to set up Pabbly Chat Flow for WhatsApp broadcasts. After logging in, navigate to the dashboard where you can see the option to connect your WhatsApp number. If you haven’t connected it yet, follow the instructions provided in the tutorial available on their YouTube channel.
Next, to create a broadcast, go to the broadcast section. Here are the steps to follow:
- Click on the “Add” button to create a new broadcast.
- Choose the type as “Broadcast Campaign”.
- Name your broadcast, for example, “New Fashion Show”.
After naming your broadcast, you will see options to select your audience. You can either choose an existing contact list or upload a CSV file. Make sure to prepare your CSV file if you are opting for that method. Using Pabbly Connect ensures that your data is seamlessly integrated for effective communication.
3. Creating a Message Template in Pabbly Chat Flow
Now that you have set up your broadcast, the next step is to create a message template using Pabbly Chat Flow. Navigate to the templates section where you can see various approved templates. Here, you can create a new template or use an existing one.
For this tutorial, I will use a pre-approved template. You can customize it by adding images or variables to make it more engaging. Here are the steps to create your template:
- Select the template you wish to use.
- Attach an image to enhance your message.
- Ensure the template is approved by Meta for WhatsApp.
Using Pabbly Connect allows you to send these messages effectively to multiple contacts, enhancing your outreach to clients.
4. Sending Broadcast Messages via Pabbly Connect
Once your template is ready, it’s time to send the broadcast. You will return to the broadcast section in Pabbly Connect. Here, you can see the total broadcasts, live broadcasts, and scheduled broadcasts.
Follow these steps to send your broadcast:
- Click on the “Send Test Message” button to verify your message.
- Enter your WhatsApp number to receive the test message.
- Check your WhatsApp for the test message confirmation.
After testing, you can schedule your broadcast for a later time or send it immediately. Pabbly Connect ensures that your messages are sent to all valid contacts, making your outreach seamless.
5. Monitoring Broadcast Performance with Pabbly Connect
After sending your broadcast, it’s crucial to monitor its performance. In Pabbly Connect, you can view statistics regarding the messages sent, delivered, read, and failed.
To check the performance:
- Go to the broadcast statistics section.
- Review the data on messages sent and received.
- Use this data to improve future broadcasts.
Pabbly Connect not only aids in sending messages but also provides valuable insights for better engagement with your audience.
In this tutorial, we explored how to automate WhatsApp broadcasts using Pabbly Connect and Pabbly Chat Flow. By following these steps, you can effectively reach your clients and enhance your communication strategy.
