1. Accessing Pabbly Connect for Your Booking Automation
To start automating your booking process, first, you need to access Pabbly Connect. This integration platform allows you to connect various applications seamlessly. Open your browser and visit the Pabbly website, where you can either sign in if you are an existing user or create a new account.
Once logged in, navigate to the Pabbly Connect dashboard. This is where you will initiate your integration with Pabi Chatflow. Ensure you have your WhatsApp number ready, as you will need it to set up your chatbot for booking appointments.
2. Creating Your WhatsApp Chatbot Using Pabi Chatflow
Next, you will create a WhatsApp chatbot using Pabbly Connect and Pabi Chatflow. Start by accessing the Pabi Chatflow page at pave.com/chatflow. Here, you will find options to sign up or log in. New users can sign up for free and receive 100 credits for testing.
  • Sign up for a free account to get started.
  • Log in to access the flow creation page.
  • Add your WhatsApp number to your Pabi account.
After logging in, you can create a new flow for your WhatsApp booking bot. Name your flow appropriately, such as “WhatsApp Booking Bot Setup for Beginners.” This will help you easily identify it later in your Pabbly Connect dashboard.
3. Setting Up Triggers in Pabbly Connect
Triggers are essential for initiating your WhatsApp chatbot. In Pabbly Connect, you will set a trigger event that starts the chatbot interaction. Choose a keyword that will activate the chatbot, such as “hello.” This is the word customers will type in WhatsApp to start booking.
Once the trigger is set, you will drag and drop action blocks to build your chatbot flow. For example, you can create a welcome message that users will receive when they initiate the conversation. Make sure to test the flow to ensure that it responds correctly to the trigger.
4. Collecting User Data for Bookings
After setting up the welcome message, your next step is to collect essential user data. Using Pabbly Connect, you will ask users for their preferred date and time for the appointment. Create a series of questions to gather this information, ensuring that you have fields for date, time, and full name.
  • Ask users for their preferred date.
  • Request their preferred time for the appointment.
  • Collect their full name for booking confirmation.
This data will be crucial for managing appointments effectively. Once the user provides their information, you will need to integrate this data with Google Sheets using Pabbly Connect.
5. Integrating with Google Sheets Using Pabbly Connect
The final step involves integrating your WhatsApp chatbot with Google Sheets through Pabbly Connect. This integration allows you to automatically save booking data in a structured format. Use the API request feature in Pabbly Connect to send data to your Google Sheets.
In the API request node, select the POST method and enter the webhook URL generated by Pabbly Connect. Map the data collected from users to the appropriate fields in Google Sheets. This ensures that every booking is accurately recorded.
By following this tutorial, you can effectively automate your booking process using Pabbly Connect and Pabi Chatflow. This integration not only saves time but also enhances user experience, allowing customers to book appointments effortlessly. Start using Pabbly Connect today to streamline your business operations.
