1. Accessing Pabbly Connect to Create Your WhatsApp Chatbot
To start automating WhatsApp responses, you first need to access Pabbly Connect. Open your browser and navigate to the Pabbly website, specifically the Pabbly Chartflow section.
Once there, you can either sign up for a free account or log in if you are an existing user. After logging in, you will be directed to the dashboard where you can begin creating your WhatsApp chatbot.
2. Setting Up WhatsApp Integration with Pabbly Connect
In this section, you will set up your WhatsApp number within Pabbly Connect. Go to the settings and add your WhatsApp number. This step is crucial for enabling automated responses.
After adding your number, navigate to the “Flows” feature on the left sidebar. Here, you can create and manage your chatbot flows using a user-friendly drag-and-drop builder. Follow these steps to set up your flow:
- Click on the “Add Flow” button.
- Name your flow and select a trigger event.
- Choose the template for your message.
Now that your flow is created, you can start customizing it based on your business needs.
3. Customizing Your Chatbot Flow in Pabbly Connect
With your flow created, it’s time to customize it. In Pabbly Connect, you can add various buttons and messages to enhance user interaction. Begin by selecting the template you want to use for your automated messages.
Next, add a list button for destination types. You can create a dynamic list from which users can choose their preferred destinations. Follow these steps to customize your flow:
- Enter the header and body for your message.
- Add items to your destination list.
- Link your list to the appropriate buttons.
This setup allows your chatbot to respond intelligently to user selections, enhancing the overall customer experience.
4. Adding User Input Questions in Pabbly Connect
After setting up your destination options, you can start adding questions for user input. In Pabbly Connect, you can customize the questions your chatbot will ask users based on their selections.
For instance, you can ask users for their travel dates, number of travelers, and budget. Here’s how to do it:
- Create questions using the “Question Node” feature.
- Set the format for each question (text or number).
- Link the questions to the next steps in your flow.
This will ensure your chatbot collects all necessary information seamlessly from users.
5. Finalizing Your Chatbot Flow in Pabbly Connect
Once all questions are added, it’s time to finalize your flow in Pabbly Connect. This involves setting up confirmation messages and ensuring that all nodes are connected properly.
For the final step, create a confirmation message that dynamically includes user inputs. You can use the dollar symbol to reference custom fields. Follow these steps:
- Add a text button for the confirmation message.
- Link the button to the final response.
- Save your flow to activate it.
With these steps, your WhatsApp chatbot is fully functional and ready to interact with customers automatically.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect. By following the detailed steps, you can automate customer interactions effectively. Start using Pabbly Connect today to enhance your business operations.
