1. Accessing Pabbly Chatflow for Automation
To start automating WhatsApp reminders and confirmations, we will use Pabbly Chatflow. First, visit the Pabbly Chatflow landing page and click on the “Get Started” button.
Once you are on the platform, you can choose a plan that suits your needs. For beginners, the free trial is a great option. After signing up, access the Pabbly Chatflow dashboard to begin creating your automation workflows.
2. Creating a New Workflow in Pabbly Chatflow
After accessing Pabbly Chatflow, click on the “Create Workflow” button. You will be prompted to name your workflow; enter a name like “Automate WhatsApp Reminders”.
  • Provide the requirements for your automation.
  • Specify the applications involved: Google Forms for data collection and Pabbly Chatflow for sending messages.
  • Set the trigger to activate the workflow when a new Google Form response is submitted.
After entering your requirements, Pabbly Chatflow will analyze them and create a workflow that will automatically send WhatsApp confirmations and reminders based on the details submitted through Google Forms.
3. Setting Up WhatsApp Integration with Pabbly Chatflow
In this step, you will configure how Pabbly Chatflow sends WhatsApp messages. You need to provide the Pabbly Chatflow API key and phone number ID from your Pabbly account settings.
To get your API key, navigate to the settings in your Pabbly Chatflow account, and copy the API token. Paste it into the required field in your workflow setup. This will allow Pabbly Chatflow to authenticate and send messages via WhatsApp.
  • Ensure that the API key is correctly entered.
  • Set up the WhatsApp message templates for confirmations and reminders.
  • Test the integration to ensure messages are sent properly.
Once these configurations are complete, Pabbly Chatflow will handle sending WhatsApp messages automatically whenever a new appointment is booked through Google Forms.
4. Testing Your Pabbly Chatflow Automation
After setting up the automation, it is crucial to test it to ensure everything works as expected. Use the Google Form to submit a test appointment. For instance, fill in the client’s name, WhatsApp number, service, appointment date, and time.
Once you submit the form, Pabbly Chatflow will trigger the workflow. You should receive a WhatsApp confirmation message immediately and a reminder one hour before the appointment. This demonstrates how efficiently Pabbly Chatflow automates the process.
  • Check the WhatsApp for the confirmation message.
  • Verify the reminder is sent at the correct time.
  • Ensure all details are accurately reflected in the messages.
This testing phase confirms that your integration is functioning correctly and that Pabbly Chatflow is effectively managing your WhatsApp communications.
5. Finalizing Your Pabbly Chatflow Setup
Once testing is complete and everything is functioning as intended, finalize your workflow in Pabbly Chatflow. Review all settings, ensure that the API key and phone number ID are correct, and that your message templates are ready.
With everything set, you can now relax as Pabbly Chatflow automates your WhatsApp confirmations and reminders. You won’t need to manually follow up with clients, allowing you to focus on other aspects of your business.
By using Pabbly Chatflow, you can automate WhatsApp reminders and confirmations seamlessly. This integration saves time and enhances client communication without any coding skills required.
