To start automating WhatsApp replies for your booking system, first access Pabbly Connect by visiting pabyt.com/chartflow in your web browser. This will take you to the Pabbly Chartflow homepage, where you can either sign in or sign up for a free account.
If you are a new user, click on the “Sign up free” button to create your account. Existing users can simply sign in. After logging in, you will see all Pabbly applications, including Pabbly Chartflow, which is essential for creating your WhatsApp AI chatbot.
2. Creating Your WhatsApp AI Chatbot with Pabbly Connect
Once you are in Pabbly Chartflow, you will need to connect your WhatsApp number. To do this, click on the “Add” button. You will see two methods to connect your WhatsApp account. Choose the method that suits you best.
  • Select the connection method from the options provided.
  • Follow the on-screen instructions to link your WhatsApp account.
After connecting your WhatsApp number, you can start creating your AI assistant. Click on the “Add” button under the AI Assistant section and name your assistant. This is where Pabbly Connect truly shines, enabling seamless integration of your WhatsApp communication.
3. Configuring Your AI Assistant in Pabbly Connect
Now that your assistant is created, it’s time to configure it. Start by selecting the instruction type from the dropdown menu. You can choose a custom prompt or select predefined options like AI agent or customer support agent.
For this tutorial, select the AI agent option. This will automatically populate some basic instructions, which you can customize as needed. Next, set the AI configuration parameters such as temperature and select the AI to use, which is OpenAI in this case.
  • Set the temperature to determine the creativity of responses.
  • Input your OpenAI API key to enable the AI assistant.
These configurations ensure that your WhatsApp AI assistant responds accurately to customer inquiries, showcasing the capabilities of Pabbly Connect in automating your business processes.
4. Training Your AI Assistant with Knowledge Sources
To improve response accuracy, it’s essential to provide a knowledge source for your AI assistant. Create a document that includes your business details and FAQs. Download this file in plain text format, as PDF files have limitations.
Once your document is ready, upload it in the Pabbly Chartflow interface. This step is crucial because it allows your AI assistant to access relevant information and respond to customer queries effectively.
  • Ensure your document includes all necessary information about your business.
  • Upload the document in the specified format to enable your assistant to use it.
With the knowledge source in place, your assistant will be well-equipped to handle customer inquiries, demonstrating the power of Pabbly Connect in enhancing customer interactions.
5. Assigning Your AI Assistant to WhatsApp Chats
After configuring your AI assistant, you need to assign it to your WhatsApp chats. Go to the inbox settings in the Pabbly Chartflow dashboard. Scroll down to find the AI auto-reply settings.
Enable the auto-reply feature, select your contact list, and choose the assistant you just created. Click the save button to apply these settings. This allows your assistant to respond to all contacts in the selected list automatically.
  • Choose whether to assign the assistant to a single chat or multiple chats.
  • Confirm the settings to ensure the assistant is active for your WhatsApp interactions.
By following these steps, you can effectively manage customer inquiries through WhatsApp, highlighting the efficiency of Pabbly Connect in automating communication processes.
In this tutorial, we explored how to automate WhatsApp replies using Pabbly Connect. By creating a WhatsApp AI chatbot, you can enhance customer interactions and streamline your booking system. This integration not only saves time but also improves customer satisfaction.
