1. Accessing Pabbly Connect for WhatsApp Chatbot
To create a WhatsApp chatbot, first, you need to access Pabbly Connect. Open your browser and navigate to www.pabbly.com/chatflow. This is where you will set up your chatbot integration.
Once on the Pabbly website, sign in to your account. If you are a new user, you can sign up for free, which gives you some credits to test the features. After signing in, you will be directed to the Pabbly apps page. Here, you can select Pabbly Chat Flow to start your chatbot setup.
2. Setting Up Your WhatsApp Chatbot
Now that you are in Pabbly Connect, the next step is to create your WhatsApp chatbot. Click on the “Add WhatsApp Number” option. You can connect your WhatsApp using the preferred method or a manual token.
- Select the WhatsApp connect option.
- Follow the prompts to link your WhatsApp account.
- Once connected, navigate to the AI assistant section to create your chatbot.
After connecting your WhatsApp, head to the AI assistant page. Click on “Add AI Assistant” and name it accordingly. For example, you can name it “WhatsApp AI Chatbot for Investors”. This will be the chatbot that interacts with your customers.
3. Configuring Your AI Assistant with Pabbly Connect
In this section, you will configure your AI assistant using Pabbly Connect. Select the instruction type as “AI agent”. This sets the framework for how your chatbot will respond to queries.
Next, you need to configure the AI settings. Set the temperature for responses; 0 means focused, while 1 means creative. Choose a value like 0.8 for balanced responses. Enter your API key from OpenAI, which is crucial for the AI’s functionality.
- Generate a new API key from OpenAI.
- Paste the API key in the designated field in Pabbly Connect.
- Save the key to ensure your AI assistant can function correctly.
After entering the API key, toggle on the settings for header and footer messages as needed. This helps personalize your chatbot’s responses.
4. Uploading Your Knowledge Base to Pabbly Connect
To enhance your chatbot’s functionality, upload a knowledge base using Pabbly Connect. This is where you will input all the relevant information your AI assistant will use to respond to queries.
Click on the “Upload File” option and select the file containing your business information. Ensure that the file is in .txt or .pdf format. For PDFs, note that the limit is 10 pages if images are included.
- Prepare your knowledge base with FAQs, services offered, and other relevant details.
- Upload the file and confirm successful upload.
- Select the uploaded file to be used as the knowledge source.
Once your knowledge base is uploaded, your AI assistant will be equipped to provide detailed responses based on the information provided.
5. Assigning Your AI Assistant to Contacts via Pabbly Connect
Finally, you can assign your AI assistant to specific contacts or groups using Pabbly Connect. Open the inbox settings and enable AI auto-reply settings.
Select the contact list you want to assign the AI assistant to. You can create multiple rules to assign different assistants to different lists.
- Choose the appropriate AI assistant for each contact list.
- Save the settings to ensure everything is configured correctly.
- Test the AI assistant by sending messages to see if it responds accurately.
By following these steps, you can ensure that your WhatsApp chatbot is fully functional and ready to assist your customers effectively.
In this tutorial, you learned how to create a WhatsApp chatbot using Pabbly Connect and integrate it with various applications. This setup allows for seamless interactions with customers, enhancing your business communication.
