To create an automated WhatsApp assistant, the first step is accessing Pabbly Connect. This platform serves as the central hub for integrating various applications without requiring coding skills.
Start by navigating to the Pabbly Connect website. Once there, you will need to sign up for an account. After signing up, you can access the dashboard where you will manage your integrations.
2. Setting Up Pabbly Chatflow with Pabbly Connect
After logging into Pabbly Connect, the next step is to set up Pabbly Chatflow, the tool that enables WhatsApp automation. To do this, navigate to the Chatflow section in your dashboard.
- Click on the ‘Create New Assistant’ button.
- Enter your WhatsApp number to link it with Pabbly Chatflow.
- Select the AI assistant option from the sidebar.
Once you have set up your WhatsApp number, you can start configuring your AI assistant. This is where you define how your assistant will respond to customer queries.
3. Configuring AI Assistant Settings in Pabbly Connect
In this section, you will configure the AI settings for your assistant using Pabbly Connect. Start by selecting the instruction type as “AI agent”.
Next, adjust the temperature setting, which determines how creative your AI responses will be. A lower value means more focused responses, while a higher value allows for more creative answers. You will also need to select OpenAI as your AI provider.
- Choose the model, such as GPT-5.2.
- Enter your OpenAI API key to connect it with your assistant.
- Click on the ‘Connect’ button to save your settings.
Once these settings are configured, your AI assistant will be ready to handle queries through WhatsApp.
4. Uploading Knowledge Base for Pabbly Connect Assistant
The next crucial step is to upload your business’s knowledge base to the assistant using Pabbly Connect. This knowledge base acts as the brain of your AI assistant, enabling it to provide accurate responses.
To upload the knowledge base, go to the knowledge source section and select the file you want to upload. Ensure that it is in the correct format, such as PDF or TXT. After selecting the file, click the insert button to upload it.
- Provide a name for your knowledge base.
- Confirm that the upload was successful by checking the preview.
- Make any necessary adjustments to the knowledge base content.
This step ensures that your AI assistant can answer queries based on the information provided in your knowledge base.
5. Finalizing and Activating Your Pabbly Connect Assistant
The final step is to finalize and activate your AI assistant using Pabbly Connect. Navigate to the settings tab where you can customize the appearance and initial messages of your assistant.
Here, you can set the display name, subheading, and initial greeting messages. Make sure to enable the powered by Pabbly label if you want it to appear on the assistant interface.
- Click the ‘Save Assistant’ button to finalize your settings.
- If you want to embed the assistant on your website, click the embed button to get the script code.
- Paste the script code into your website’s HTML to integrate the assistant.
After completing these steps, your WhatsApp assistant will be fully operational, ready to assist your customers automatically.
Using Pabbly Connect, you can create an efficient WhatsApp assistant that automates customer responses without coding. This integration enhances customer service and saves time for businesses.
