To start using Pabbly Connect, open a new tab and navigate to pabbly.com/chatflow. If you are a new user, create your account to receive 100 free credits monthly to explore the platform.
Once logged in, you will see various Pabbly applications. Click on Pabbly Chat Flow to access its dashboard. This is where you will initiate the integration process to create your AI-powered WhatsApp assistant.
2. Creating Your AI Assistant in Pabbly Chat Flow
In Pabbly Chat Flow, navigate to the AI Assistant feature. Click on the button labeled “Add AI Assistant” to begin the setup. You will be prompted to name your assistant; for this example, let’s call it “Tool Rental AI Assistant”.
  • Click on “Add AI Assistant”.
  • Name your assistant.
  • Select the type of instruction as “AI Agent”.
This setup is crucial as it defines how your assistant will respond to customer inquiries. You can customize these rules according to your business needs.
3. Configuring AI Settings and OpenAI Integration
After naming your assistant, you need to configure the AI settings. Set the temperature to 0.5 to control the creativity of the AI responses. Next, select OpenAI as your AI service provider and choose the GPT-4 Mini version.
For the API key, visit your OpenAI API keys page and create a new secret key. Copy this key and paste it into the designated field in Pabbly Connect. Click on the “Connect” button to establish the link between your OpenAI account and the AI assistant.
4. Setting Up Knowledge Base for AI Responses
The knowledge base is essential for your assistant to provide accurate responses. Upload a .txt or .pdf file containing all relevant information about your business, such as pricing and FAQs.
  • Create a knowledge base file using Google Docs or any text editor.
  • Upload the file through the Pabbly Chat Flow interface.
  • Ensure it contains all necessary business information.
This knowledge base acts like the brain of your AI assistant, enabling it to deliver tailored responses based on customer inquiries.
5. Finalizing Your AI Assistant Settings
Once your knowledge base is uploaded, navigate to the assistant interface to customize its appearance. You can edit the title, subtitle, and initial message to suit your branding.
Finally, activate your assistant by toggling the activation button and clicking on “Save AI Assistant”. Now, your AI assistant is ready to interact with customers on WhatsApp, ensuring seamless communication.
In conclusion, using Pabbly Connect to integrate various applications like Pabbly Chat Flow and OpenAI allows you to create a powerful AI assistant for WhatsApp. This assistant can enhance customer engagement and streamline communication efficiently.
