1. Setting Up Pabbly Connect for WhatsApp Automation
To automate your WhatsApp conversations, first, access Pabbly Connect. Open your browser and navigate to the Pabbly Connect homepage. If you are a new user, sign up for a free account to get started.
After signing in, you will land on the Pabbly Connect dashboard. This is where you will manage your integrations. Here, you can create a new workflow specifically for your WhatsApp AI agent.
2. Creating Your WhatsApp AI Agent Using Pabbly Chatbot
Next, you need to create your WhatsApp AI agent. Visit Pabbly Chatbot by entering www.pabbly.com/chatbot in your browser. Once there, sign in to your account and access the dashboard.
  • Click on ‘Add AI Assistant’ to create a new assistant.
  • Name it as ‘WhatsApp AI agent for restaurants’.
  • Select AI instructions and configurations to enhance the responses.
After setting up the AI assistant, configure the AI settings, including the API key from OpenAI. This integration is crucial as it enables the AI to provide intelligent responses through Pabbly Connect.
3. Configuring AI Responses and Knowledge Base
In this section, you will configure how your AI agent responds. Within the Pabbly Chatbot dashboard, navigate to the AI settings. Set the AI configuration parameters to define how creative the responses should be.
For the knowledge base, upload a document containing your restaurant’s information, such as menu items, delivery areas, and offers. This document will be the foundation for the AI’s responses, ensuring it provides accurate and relevant information.
  • Ensure the document is in .txt or .pdf format.
  • Include all necessary details about your restaurant services.
By properly configuring these settings in Pabbly Connect, you ensure that your AI agent can effectively handle customer inquiries.
4. Assigning the AI Assistant to Contacts
Once your AI assistant is set up, you need to assign it to your contacts. Go to the inbox settings in Pabbly Connect and select the AI assistant you created.
You can assign the AI assistant to specific groups or all contacts. This feature allows for broader automation, enhancing customer engagement without manual intervention.
  • Enable AI auto-replies to automate responses.
  • Select the appropriate AI assistant for each contact list.
This setup ensures that your customers receive timely responses via WhatsApp, thanks to the seamless integration provided by Pabbly Connect.
5. Testing Your WhatsApp AI Agent
Finally, it’s time to test your WhatsApp AI agent. Send a message to your WhatsApp number and observe the responses generated by the AI agent. This step ensures that everything is functioning as expected.
During testing, ask common questions like menu inquiries or delivery times. The AI should respond accurately based on the knowledge base you provided earlier through Pabbly Connect.
Make adjustments as necessary to improve response accuracy. You can refine the AI settings in Pabbly Chatbot based on the feedback received during testing, ensuring a better customer experience.
In this guide, we explored how to automate WhatsApp conversations for your restaurant using Pabbly Connect. By creating an AI agent, configuring responses, and assigning it to contacts, you can enhance customer engagement and streamline communication.
