1. Accessing Pabbly Chatflow for Your WhatsApp Chatbot
To start using Pabbly Chatflow, visit the official website and sign in to your account. If you are a new user, you can sign up for free and receive 100 credits monthly to test the platform. Existing users should click on “Sign In” at the top right corner.
Once logged in, you will find a dashboard showing your available credits and WhatsApp number. To connect your WhatsApp, click on “Connect WhatsApp”. This is crucial as Pabbly Chatflow facilitates the integration between your WhatsApp account and the chatbot functionalities.
2. Creating Your AI Assistant in Pabbly Chatflow
After accessing Pabbly Chatflow, navigate to the AI Assistant section. Here, you can create a new AI assistant specifically for your photography studio. For this example, name it “Lenscraft Photography Studio” and click on “Add Assistant”.
  • Select the instruction type as AI agent.
  • Set the temperature to 0.7 for a balanced creativity level.
  • Enter your OpenAI API key to enable the AI functionalities.
By following these steps, you will effectively configure the AI assistant to respond appropriately to customer inquiries, showcasing the power of Pabbly Chatflow in automating your business communications.
3. Configuring Your AI Assistant Settings
Next, you need to configure the settings for your AI assistant within Pabbly Chatflow. This includes adding header and footer messages, setting stop keywords, and defining retry attempts for unanswered queries. These settings will enhance the user experience significantly.
For example, you can set:
  • Header message to greet users.
  • Footer message to include company contact information.
  • Stop keywords for users to opt-out of the conversation.
This detailed configuration ensures that your chatbot provides timely and relevant responses, making it a valuable asset for your photography studio through Pabbly Chatflow.
4. Uploading Your Knowledge Base to Pabbly Chatflow
To enhance your AI assistant’s capabilities, you need to upload a comprehensive knowledge base. This can be done by selecting the “Upload File” option in Pabbly Chatflow. Make sure your document contains essential business information, such as services offered, pricing, and contact details.
After uploading, confirm the file is correctly integrated into the system. This knowledge base will serve as the primary resource for your AI assistant, allowing it to answer queries accurately based on the information provided.
5. Enabling Your AI Assistant for WhatsApp Conversations
Finally, to enable your AI assistant to respond to WhatsApp inquiries, navigate to the settings in Pabbly Chatflow. Here, you can assign your AI assistant to specific contacts or groups, ensuring that it can handle incoming messages effectively.
To do this:
  • Select the AI assistant you created.
  • Toggle the auto-reply settings to enable responses.
  • Save your settings to finalize the integration.
By completing these steps, your AI assistant will be ready to engage with customers, showcasing the full potential of Pabbly Chatflow in automating your business communications.
By following this tutorial, you can successfully create and integrate a WhatsApp chatbot using Pabbly Chatflow. This system will streamline your customer interactions, making your photography studio more efficient and responsive.
