1. Accessing Pabbly Connect to Create Your WhatsApp Chatbot
To create a WhatsApp chatbot, you first need to access Pabbly Connect. Start by visiting www.pabbly.com/chatflo in your browser. This will direct you to the Pabbly Chatflo platform, where you can manage your WhatsApp chatbot.
Once on the website, sign in to your account. If you are new, you can sign up for free. After logging in, you will be directed to the Pabbly Chatflo dashboard. Here, you can view your credits and manage WhatsApp connections. Make sure to note any credits available for testing your chatbot.
2. Connecting Your WhatsApp Account to Pabbly Chatflo
To connect your WhatsApp account, click on the ‘Add WhatsApp Number’ option on your Pabbly Chatflo dashboard. You will have two methods to connect: using the WhatsApp connect feature or a manual token.
  • Choose the preferred method for connecting your WhatsApp number.
  • Follow the prompts to complete the connection process.
After connecting your WhatsApp, you can proceed to set up your AI assistant. This integration is crucial as it allows you to automate responses and engage users effectively.
3. Creating Your AI Assistant with Pabbly Chatflo
In this step, you will create an AI assistant that will handle user queries on WhatsApp. Navigate to the AI assistant section in Pabbly Connect and click on ‘Add AI Assistant’. Name your assistant, for example, ‘WhatsApp AI agent for DIY’.
Next, configure your AI assistant by selecting the AI agent type. You can customize the AI’s creativity level, setting it to 0.8 for balanced responses. Also, choose Open AI as the AI to use and enter your API key from Open AI.
  • Enter the API key obtained from Open AI.
  • Configure the fallback messages and knowledge sources for your AI assistant.
Once configured, save your AI assistant settings. This setup ensures that your chatbot can respond to user queries with relevant information.
4. Assigning Your AI Assistant to Contacts Using Pabbly Connect
After creating your AI assistant, the next step is assigning it to specific contacts or groups. In Pabbly Connect, navigate to the inbox settings where you can enable auto-replies.
Select the AI assistant you created and assign it to a particular list or all contacts. This automation helps streamline responses and ensures that users receive timely assistance.
  • Choose the list of contacts for the AI assistant.
  • Save the settings to activate the auto-reply feature.
This method allows you to efficiently manage responses and enhance user engagement through Pabbly Connect.
5. Testing Your WhatsApp Chatbot with Pabbly Connect
Once everything is set up, it’s time to test your WhatsApp chatbot. Send a message to your connected WhatsApp number and observe how the AI assistant responds. This step is crucial to ensure that the integration works seamlessly.
Ask various questions to see how well your AI assistant handles different queries. For instance, inquire about product recommendations or store details. This testing phase helps identify any adjustments needed for optimal performance.
  • Send a test message to your WhatsApp chatbot.
  • Evaluate the responses and make necessary adjustments.
By following these steps, you can effectively create a functional WhatsApp chatbot using Pabbly Connect that enhances customer interaction.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect with Simply and Here I for automation. By following the detailed steps, you can enhance customer engagement and streamline communication effectively.
