To start using Pabbly Connect for integrating your WhatsApp AI Agent for blood test labs, first navigate to the Pabbly website. Sign in to your account or create a new one if you are a first-time user.
After signing in, you will be directed to the Pabbly dashboard. From here, select Pabbly Connect to begin the integration process. This platform will serve as the central hub for connecting various applications involved in home sample collection.
2. Setting Up Your WhatsApp AI Agent
Next, you will create your WhatsApp AI Agent using Pabbly Chatflow. Go to the Pabbly Chatflow section and click on “Add AI Assistant”. Name your assistant as “WhatsApp AI Agent for Blood Test Labs” and proceed.
- Select the instruction type as “AI agent”.
- Set the creativity level to 0.8 for balanced responses.
- Choose Open AI and select the model as GPT-5 mini.
By following these steps, you are configuring your AI assistant to respond effectively to user inquiries regarding blood tests and home sample collection processes, all facilitated by Pabbly Connect.
3. Configuring API Keys for Your AI Agent
To enhance the functionality of your WhatsApp AI Agent, you need to set up API keys. Click on the provided hyperlink in the help section to access the Open AI API keys page. Create a new secret key by naming it and selecting the necessary permissions.
Once you generate the API key, copy it and paste it into the designated field in Pabbly Connect. This integration ensures that your WhatsApp AI Agent can access the required resources to answer queries about blood tests and home sample collections efficiently.
4. Finalizing Your AI Assistant’s Settings
Now that you have configured the API, it’s time to finalize your AI assistant’s settings. You can set header and footer messages, and establish stop keywords for user requests. This is essential for maintaining a smooth conversation flow.
- Enter a header message like “Hi there, how can I help you today?”.
- Add footer links to your privacy policy for user assurance.
- Define stop keywords for when users want to end the conversation.
These settings, managed through Pabbly Connect, allow your AI assistant to respond appropriately to user inquiries while providing a professional interface for blood test lab services.
5. Assigning the AI Assistant to Contacts
To make your WhatsApp AI Agent operational, you need to assign it to your contacts. This can be done through the inbox settings in Pabbly Connect. Navigate to the inbox settings and enable AI auto replies.
Here, you can select specific contact lists or even apply the AI assistant to all contacts. This ensures that whenever a user sends a message regarding blood tests, they will receive prompt and relevant responses from your WhatsApp AI Agent.
In conclusion, using Pabbly Connect to create a WhatsApp AI Agent for blood test labs streamlines home sample collection processes. By following the steps outlined, you can automate responses and enhance customer engagement effectively.
