To automate WhatsApp responses, you need to access Pabbly Connect. Start by opening your browser and navigating to the Pabbly Connect website.
Once there, create an account or log in. After logging in, ensure you connect your WhatsApp number to your Pabbly Chatbot account. This is essential for the integration to work effectively.
2. Creating Your AI Assistant with Pabbly Connect
After setting up your account, you can create your AI assistant. Click on the “AI Assistant” option in the left sidebar of Pabbly Connect. This will take you to the AI assistant setup page.
  • Select the type of AI assistant you want to create.
  • Adjust the temperature settings to control creativity.
  • Choose OpenAI as your AI provider and select the appropriate model.
These steps ensure that your assistant is tailored to your business needs. Adjust the temperature setting for your AI assistant to balance creativity and focus.
Next, you need to configure the settings for your AI assistant in Pabbly Connect. This includes entering your OpenAI API key, which connects the AI to your WhatsApp assistant.
  • Visit the OpenAI API key page to generate your key.
  • Input the API key into the appropriate field in Pabbly Connect.
  • Save your settings to ensure they are applied.
This API connection is crucial for your assistant to respond to customer inquiries using the data provided by your business.
4. Setting Up Your Knowledge Base with Pabbly Connect
Now, it’s time to set up your knowledge base, which is essential for your AI assistant to provide accurate responses. Upload your business information in a .txt or .pdf format through Pabbly Connect.
Make sure to include all relevant details about your business, as this is what the AI will use to answer customer questions. After uploading, you can check the file in your media library.
5. Customizing Your AI Assistant Interface
The final step is to customize the interface of your AI assistant. In Pabbly Connect, you can modify the appearance of the chat window, including colors and labels.
Set the initial message that users will see when they first interact with your assistant. This helps create a welcoming environment for your customers. Finally, save your settings to activate the assistant.
Using Pabbly Connect, you can automate WhatsApp responses effectively. This tutorial provided a step-by-step guide on integrating Pabbly Chatbot with OpenAI, allowing your business to respond to customer inquiries efficiently.
