To start automating Instagram captions, you need to access Pabbly Connect. If you’re a new user, visit pabbl.com/connect and sign up for free. This gives you access to 100 tasks per month, allowing you to explore the platform.
Once signed up, log into your Pabbly Connect account. This central platform will help you integrate various applications like Google Sheets and Google AI to automate your Instagram caption generation seamlessly.
2. Setting Up Google Sheets Integration with Pabbly Connect
Next, you’ll set up Google Sheets as your trigger application in Pabbly Connect. Start by creating a new workflow. Click on the “Add Trigger” button and select Google Sheets as your application. Choose “New or Updated Spreadsheet Row” as the event.
  • Choose “New or Updated Spreadsheet Row” as the event.
  • Click on the connect button to generate the webhook URL.
Copy the webhook URL and integrate it into your Google Sheets by installing the Pabbly Connect Webhooks extension. Refresh your spreadsheet to see the new extension, and configure it by pasting the copied URL and setting the trigger column.
3. Generating Instagram Captions Using Google AI with Pabbly Connect
Now that your Google Sheets is connected, it’s time to generate captions using Google AI. Click on “Add New Action Step” and select Google AI (Gemini) as your application. Choose “Generate Content” as the event.
To connect Google AI with Pabbly Connect, you’ll need to enter your API key from Google AI Studio. After entering the key, map the necessary fields for caption generation. This includes specifying the prompt that will guide the AI in generating captions based on your input data.
  • Select Google AI (Gemini) as your action application.
  • Choose “Generate Content” as the event.
  • Map the prompt fields to generate unique captions.
After setting this up, click on “Save and Send Test Request”. This will generate the Instagram caption based on the mapped data from your Google Sheets.
4. Updating Google Sheets with Generated Captions via Pabbly Connect
Once your Instagram captions are generated, you’ll want to update your Google Sheets with these captions. Click on “Add New Action Step” again and select Google Sheets. This time, choose “Update Cell Value” as the event.
Connect your Google Sheets account and specify the spreadsheet and the cell range where the generated captions should be placed. Map the row index dynamically to ensure that each new caption populates the correct row in your sheet.
  • Select Google Sheets as your action application.
  • Choose “Update Cell Value” as the event.
  • Map the row index and value to update the sheet.
Click “Save and Send Test Request” to confirm that the captions are successfully updated in your Google Sheets. You can verify this by checking the designated cells in your spreadsheet.
5. Bulk Caption Generation with Pabbly Connect
To generate captions in bulk, you can utilize the “Send All Data” feature in the Pabbly Connect Webhooks. This allows you to send all entries in your Google Sheets for caption generation in one go.
Simply go to the Pabbly Connect Webhooks extension in Google Sheets and click on “Send All Data”. This will trigger the workflow you set up earlier, generating captions for all the posts in your sheet with a single click.
By using Pabbly Connect, you can automate this entire process, making your Instagram caption generation quick and efficient. Additionally, enabling the “Send on Event” option will ensure that new entries automatically generate captions as they are added to your Google Sheets.
In this tutorial, we explored how to automate Instagram captions using Pabbly Connect. By integrating Google Sheets and Google AI, you can effortlessly generate captions for multiple posts in a matter of seconds. This automation not only saves time but also enhances your social media strategy.
