1. Introduction to Pabbly Connect for WhatsApp Integration
Pabbly Connect is a powerful integration platform that allows you to automate workflows between various applications, including WhatsApp and OpenAI. In this tutorial, you will learn how to set up an advanced AI WhatsApp assistant using Pabbly Connect.
First, you need to access Pabbly Connect by visiting their official website. Once you have signed up or logged in, you can start creating your integrations. This process will enable you to automate responses on WhatsApp, enhancing customer interaction significantly.
2. Creating Your AI WhatsApp Assistant with Pabbly Connect
To create your AI WhatsApp assistant, navigate to the Pabbly Chatflow section within Pabbly Connect. Here, you will find options to set up your AI assistant. Start by clicking on the ‘Create New Assistant’ button.
  • Select the AI agent type.
  • Enter your WhatsApp number.
  • Configure the AI settings, including temperature and API key.
After setting these parameters, click on ‘Save’ to create your assistant. This assistant will now be able to respond to customer inquiries automatically via WhatsApp.
3. Configuring the Knowledge Base for Your AI Assistant
The next step involves setting up a knowledge base for your AI assistant. This knowledge base acts as the brain of your assistant, allowing it to provide accurate answers to customer queries. In Pabbly Connect, you can upload a .txt or PDF file containing your business information.
To upload your knowledge base, follow these steps:
  • Click on ‘Add New File’ in the knowledge source section.
  • Select your knowledge base document from your device.
  • Confirm the upload to complete the process.
Once your knowledge base is uploaded, your AI assistant will be equipped to handle customer inquiries efficiently.
4. Enabling AI Replies on WhatsApp Using Pabbly Connect
After configuring your AI assistant and knowledge base, the next step is to enable AI replies on WhatsApp. This is done through the settings in Pabbly Connect. Go to the inbox settings and enable the AI auto-replies feature.
To enable this feature, perform the following steps:
  • Navigate to the settings menu in Pabbly Connect.
  • Select ‘Inbox Settings’ and scroll to AI auto replies.
  • Choose your contact list and select the AI assistant you created.
By enabling this feature, your AI assistant will automatically respond to messages received on WhatsApp, providing a seamless customer experience.
5. Testing Your AI Assistant Integration with Pabbly Connect
Now that your AI assistant is set up and enabled, it’s time to test its functionality. Send a message to your WhatsApp number and observe how the AI assistant responds. This will ensure that your integration is working as intended through Pabbly Connect.
To test your assistant, follow these steps:
  • Open WhatsApp and send a message to your business number.
  • Wait for the AI assistant to respond based on the knowledge base.
  • Check for accurate responses related to your business.
Testing ensures that your AI assistant is fully operational, providing quick and accurate responses to customer inquiries.
In this tutorial, you learned how to integrate WhatsApp with OpenAI using Pabbly Connect. By following the steps outlined, you can automate customer interactions and enhance your business efficiency. Start using Pabbly Connect to create your AI WhatsApp assistant today!
