1. Accessing Pabbly Connect for WhatsApp Automation
To begin unlocking more sales with WhatsApp Broadcast Automation, access Pabbly Connect via your browser. Simply navigate to pabbly.com/chatflow to reach the Pabbly Chat Flow homepage.
If you are a new user, click on ‘Sign Up Free’ to create an account. Existing users can log in directly. Once logged in, you will see the Pabbly applications window, where you can select Pabbly Chat Flow to start the integration process.
2. Setting Up WhatsApp Broadcasts Using Pabbly Connect
After accessing Pabbly Chat Flow, you will need to set up a WhatsApp Broadcast. This process involves creating a message template that you wish to send to your contacts.
  • Navigate to the templates section to create your message.
  • Ensure your template is approved by Meta for WhatsApp use.
  • Add an image to make your message more engaging.
Once your template is ready, move to the Broadcast section within Pabbly Connect. Here you can create a new broadcast campaign by clicking on the ‘Add Broadcast’ button.
3. Importing Contacts for Your WhatsApp Broadcast
Within the broadcast setup, you will need to select your audience. This is where Pabbly Connect shines by allowing you to import contacts from various sources.
You can either choose an existing list of contacts or upload a CSV file containing new contacts. If using Google Sheets, download your data as a CSV file first, then import it into Pabbly Connect.
  • Select your audience from the existing contact list.
  • Use the import feature to upload your CSV file.
After importing, you can refine your audience by excluding any contacts you don’t wish to send messages to, ensuring targeted communication through Pabbly Connect.
4. Scheduling Your WhatsApp Broadcast in Pabbly Connect
Scheduling your broadcast is a crucial step to ensure timely delivery. In Pabbly Connect, you can choose to send your message immediately or schedule it for a later time.
To schedule, select ‘Yes’ for sending at a later date and time. Make sure to choose a future date; otherwise, the message will send immediately. Additionally, you can set up automatic retries for failed messages.
  • Choose the date and time for your scheduled broadcast.
  • Enable automatic retries for failed messages if desired.
After setting your schedule, confirm the broadcast creation in Pabbly Connect to finalize your settings.
5. Analyzing Broadcast Results with Pabbly Connect
Once your WhatsApp Broadcast has been sent, it’s essential to analyze its performance. Pabbly Connect provides detailed statistics for your broadcast.
You can view metrics such as sent, delivered, read, and failed messages. This data helps you understand the effectiveness of your broadcast and allows for adjustments in future campaigns.
  • Check the number of messages sent and delivered.
  • Review read and ignored statistics to gauge engagement.
With these insights, you can improve your future broadcasts and ultimately unlock more sales through effective communication using Pabbly Connect.
In this tutorial, we explored how to unlock more sales through WhatsApp Broadcast Automation using Pabbly Connect. By following these steps, you can efficiently reach your customers and enhance your marketing efforts.
