To start using Pabbly Chatflow for your WhatsApp integration, first, open your browser and navigate to pav.com/chartflow. This will take you to the Pabbly Chatflow homepage where you can either sign up for free or log in if you already have an account.
If you are a new user, click on the “Sign Up Free” button to create your account. Existing users can simply sign in. After logging in, you will be directed to the dashboard where you can access various features of Pabbly Chatflow.
2. Connecting WhatsApp to Pabbly Chatflow
Once you are on the Pabbly Chatflow dashboard, the next step is to connect your WhatsApp number. This is essential for sending messages through the platform. To connect your WhatsApp number, navigate to the settings and follow the prompts to link your account.
- Go to the settings menu in Pabbly Chatflow.
- Select “Connect WhatsApp” option.
- Follow the instructions to verify your number.
After successfully connecting your WhatsApp number, you will be ready to set up your broadcast messages. Make sure to check the available tutorials on the Pabbly YouTube channel for more detailed guidance on connecting your WhatsApp account.
3. Creating a WhatsApp Broadcast in Pabbly Chatflow
To create a WhatsApp broadcast, click on the “Broadcast” feature in the left sidebar of Pabbly Chatflow. Here, you will find options to manage your broadcasts, including creating new ones.
Click on the “Add Broadcast” button to start a new campaign. You will need to fill in the broadcast name and select the type of broadcast you want to create. In this case, choose “Broadcast Campaign” and name it something relevant, like “Bulk Messages”.
- Select the contact list from which to send messages.
- Choose the message type: pre-approved template or regular message.
- Test your broadcast by sending it to your own WhatsApp number.
Once you have configured all settings, you can proceed to schedule or send the broadcast immediately. This feature allows you to reach all your contacts efficiently using Pabbly Chatflow.
4. Uploading Contacts from Google Sheets to Pabbly Chatflow
To send WhatsApp messages to your contacts stored in Google Sheets, you first need to upload these contacts to Pabbly Chatflow. Download your Google Sheets data as a CSV file to do this.
After downloading the CSV file, go to the “Contacts” section in Pabbly Chatflow. Click on the “Add Contact” button and select the option to upload a CSV file. This will allow you to add multiple contacts at once, making it easier to manage your messaging campaigns.
5. Testing and Scheduling Your Broadcast
Before sending your broadcast, it’s crucial to test it. In Pabbly Chatflow, you can send a test message to your own WhatsApp number. This ensures that everything appears correctly before reaching your audience.
After testing, you can choose to send the broadcast immediately or schedule it for a later time. Select the date and time for the broadcast, and then confirm your settings. This flexibility allows you to manage your messaging campaigns effectively.
Once the broadcast is sent, you can track its performance through the statistics provided in Pabbly Chatflow. This includes metrics on sent, delivered, and read messages, ensuring you can optimize future campaigns.
In this tutorial, we explored how to use Pabbly Chatflow for integrating WhatsApp with Google Sheets. By following the outlined steps, you can efficiently send bulk messages to your contacts, enhancing your communication strategy. Start using Pabbly Chatflow today to streamline your messaging process!
