To set up unlimited WhatsApp broadcast messaging, first, you need to access Pabbly Connect. Open your browser and navigate to paby.com/chatflow to reach the Pabbly Chatflow homepage. Here, you will find options to sign up for free or log in if you’re an existing user.
If you’re new, click on the ‘Sign up for free’ button to create an account. Once logged in, you will see the Pabbly apps window. From here, access Pabbly Connect by clicking on the ‘Access Now’ button, which will take you to the Pabbly Chatflow dashboard.
2. Setting Up WhatsApp Broadcast in Pabbly Connect
After logging into Pabbly Connect, you need to set up your WhatsApp broadcast. In the dashboard, locate the broadcast feature. Click on it to view existing broadcasts and options to create a new one.
  • Click on the ‘Add Broadcast’ button.
  • Choose a broadcast type for your campaign.
  • Enter a name for your broadcast campaign.
For instance, name your broadcast as ‘New Sale Alert’. This name will help you identify the broadcast later. After naming your campaign, select the contact list to whom you want to send the WhatsApp messages.
3. Importing Contacts from Google Sheets to Pabbly Connect
To send messages via WhatsApp, you need to import your contact list into Pabbly Connect. If your contacts are stored in Google Sheets, download this data as a CSV file first. Once you have the CSV file, return to the Pabbly Chatflow dashboard.
  • Navigate to the ‘Contacts’ section.
  • Click on ‘Add Contact’ and choose the bulk upload option.
  • Upload the CSV file containing your contacts.
After uploading, your contacts will be added to Pabbly Connect. You can create a separate contact list for better organization or use an existing one for your broadcast.
4. Creating a Message Template for WhatsApp Broadcast
Before sending your broadcast, you need to create a message template within Pabbly Connect. This template is crucial for personalizing your messages. Navigate to the template section in Pabbly Chatflow and create a new template.
For instance, you might draft a ‘Sale Alert’ message. Ensure this template is approved by Meta, as only approved templates can be used for bulk messaging. Once your template is ready, you can select it when setting up your broadcast.
5. Scheduling and Sending the WhatsApp Broadcast
After setting up your broadcast and selecting a message template, it’s time to send your WhatsApp messages. In Pabbly Connect, you can either send your messages instantly or schedule them for later. If you choose to schedule, select a future date and time.
  • Confirm the date and time for your scheduled broadcast.
  • Click on the ‘Add Broadcast’ button to finalize.
  • Review the broadcast stats after sending.
Once the broadcast is sent, you can view delivery stats, including sent, delivered, and read messages. This feature allows you to track the effectiveness of your messaging campaign through Pabbly Connect.
Using Pabbly Connect for unlimited WhatsApp broadcast messaging streamlines communication for businesses. By following the steps outlined, you can efficiently reach your audience with personalized messages, enhancing customer engagement.
