1. Accessing Pabbly Chatflow for WooCommerce Integration
To start using Pabbly Chatflow, visit the Pabbly website and sign in to your account. If you are new, you can sign up for free and get access to 100 tasks monthly. This allows you to explore how Pabbly Chatflow works with WooCommerce.
After signing in, navigate to the Pabbly Connect dashboard. Here, you will be able to create workflows that connect WooCommerce with Pabbly Chatflow. This integration will allow you to automate notifications for new orders placed on your WooCommerce store.
Once you are in the Pabbly Connect dashboard, click on the option to create a new workflow. Name your workflow something like “WooCommerce Orders to WhatsApp Notifications.” Choose the new beta workflow builder for a streamlined experience.
  • Select WooCommerce as your trigger application.
  • Set the trigger event to “New Order Created.”
  • Connect your WooCommerce account to Pabbly Chatflow.
After connecting, you will be provided with a webhook URL. Copy this URL as it will be used to link your WooCommerce store with Pabbly Chatflow. Ensure that the webhook is set up correctly in your WooCommerce settings to receive notifications whenever a new order is placed.
3. Configuring the Webhook in WooCommerce
To configure the webhook, go to your WooCommerce settings in WordPress. Navigate to the “Advanced” tab and select “Webhooks.” Here, you can add a new webhook by clicking on the “Add Webhook” button.
  • Name your webhook (e.g., “New Order Notification”).
  • Set the status to “Active.”
  • Paste the webhook URL from Pabbly Chatflow.
  • Select the topic as “Order Creation.”
Once you save the webhook, it will be updated successfully. This allows Pabbly Chatflow to receive notifications every time a new order is created in WooCommerce.
4. Sending WhatsApp Messages Using Pabbly Chatflow
After successfully setting up the webhook, the next step is to send WhatsApp messages using Pabbly Chatflow. Go back to your workflow and add a new action step. Select Pabbly Chatflow as your action application.
Choose the action event as “Send Template Message” and connect your Pabbly Chatflow account. You will need to enter your API token to establish this connection. This token allows Pabbly Chatflow to send messages on your behalf.
  • Specify the recipient’s mobile number, ensuring it includes the country code.
  • Select the WhatsApp template you created for order notifications.
  • Map the variables such as customer name, product, address, and total amount.
Once all details are entered, save the action step. This configuration will ensure that every time a new order is placed, the customer receives a WhatsApp notification automatically via Pabbly Chatflow.
5. Testing the Workflow and Finalizing Setup
To test your setup, create a new order in your WooCommerce store. After placing the order, check your WhatsApp for the notification. If everything is configured correctly, you should receive a message with the order details.
This testing phase is crucial to ensure that the integration between WooCommerce and Pabbly Chatflow is functioning as expected. If you encounter any issues, revisit the webhook settings and the action steps in Pabbly Chatflow to troubleshoot.
Once confirmed, your automation workflow is complete! Now, every time a new order is placed, customers will receive instant WhatsApp notifications, enhancing their shopping experience and keeping them informed.
This tutorial demonstrated how to integrate WooCommerce orders with Pabbly Chatflow for instant WhatsApp notifications. By following the steps outlined, you can automate customer communications effectively.
