To start integrating WhatsApp with Pabbly Connect, first, you need to access your Pabbly Connect account. This is essential for creating automated workflows that will handle your WhatsApp inquiries efficiently. Begin by logging into your Pabbly Connect account and navigating to the workflows section.
Once you are on the dashboard, click on the “Create Workflow” button. This step is crucial as it sets the stage for your integration. You will need to name your workflow and select the applications involved, mainly focusing on WhatsApp and Pabbly Connect.
2. Creating a WhatsApp Chatbot with Pabbly Chatflow
Now, let’s create a WhatsApp chatbot using Pabbly Chatflow. This chatbot will help filter serious inquiries from casual browsers. First, access your Pabbly Chatflow account and navigate to the “Flows” section. Here, click on the “Add Flow” button to start building your chatbot.
  • Select a trigger event for your chatbot.
  • Choose “Keyword or Regex Match” as the trigger.
  • Input the keyword “property” to trigger the chatbot.
This setup ensures that whenever a user sends the keyword “property” in WhatsApp, your chatbot will activate. This is where Pabbly Connect plays a vital role in connecting the responses to your sales team.
3. Configuring the Chatbot Responses
Next, configure the responses your WhatsApp chatbot will send. After setting the trigger, it’s time to craft the welcome message. Use the “Text” action to create a welcoming response for users who engage with the chatbot.
Include options for users to either find a property or talk to an agent. This interaction is essential for qualifying leads. Here’s how to set up the buttons:
  • Create a button labeled “Find Property”.
  • Add another button labeled “Talk to Agent”.
These buttons help guide users through the inquiry process, allowing them to provide their property preferences. The responses will be sent to Pabbly Connect for further qualification.
4. Sending Customer Responses to Pabbly Connect
Once users interact with the chatbot, their responses must be sent to Pabbly Connect for processing. To do this, use the “API Request” action in your chatbot flow. Set the request type to “POST” and enter the webhook URL provided by Pabbly Connect.
Make sure to include the necessary data fields such as customer name, email, and property preferences. This data will be crucial for qualifying leads. Here’s how to set it up:
  • Select the webhook URL from your Pabbly Connect account.
  • Map the customer responses to the relevant fields.
  • Test the API request to ensure data is flowing correctly.
By doing this, you ensure that all customer data is captured and sent to your sales team for immediate follow-up. This integration is seamless with Pabbly Connect.
5. Notifying Your Sales Team via Slack
After qualifying the leads, the final step is to notify your sales team. Use Pabbly Connect to send a message to your Slack channel. Select Slack as your action application and choose the “Send Channel Message” event.
Fill in the channel ID and map the message content from the AI response that qualifies the lead. This allows your team to receive instant notifications about hot leads. Here’s how to finalize this step:
  • Choose the Slack channel where notifications should be sent.
  • Map the message content from the previous step.
This integration ensures that your sales team is always updated about potential clients, enhancing response times and improving lead management. The entire process is streamlined through Pabbly Connect.
In conclusion, using Pabbly Connect and Pabbly Chatflow to automate WhatsApp inquiries transforms how you handle leads in your real estate business. This integration allows for efficient lead qualification and immediate notifications to your sales team, ensuring that serious buyers receive the attention they need.
