1. Accessing Pabbly Connect for WhatsApp Broadcasting
To start using Pabbly Connect for WhatsApp broadcasting, first, navigate to Pabbly Connect at pabby.com/chartflow. If you’re new, click on “Sign Up Free” to create an account and receive 100 credits monthly. Existing users can simply sign in to access their dashboard.
Once logged in, locate the “Access Now” button for Pabbly Chatflow. This will direct you to the dashboard where you can manage your WhatsApp broadcasts. Setting up your account is crucial for utilizing the broadcasting features effectively.
2. Creating a WhatsApp Template Using Pabbly Connect
After accessing Pabbly Connect, the next step is to create a WhatsApp template. This template should include images and offers to attract user attention. Navigate to the “Templates” section and click on the “Plus Add Template” button to start.
  • Select the template category, such as “Marketing”.
  • Name your template (e.g., “Solar Installation Offer”).
  • Choose the language and variable type for personalization.
  • Enter the content of your template and add any quick buttons needed.
After filling out these details, click on the “Submit” button. Your template will be reviewed and approved by Meta. This is how easily you can create a WhatsApp template using Pabbly Connect.
3. Adding Contacts to Your Pabbly Connect Account
Once your template is ready, the next step is to add contacts to your Pabbly Connect account. Navigate to the “Contacts” feature and click on “Plus Add Contacts”. You can add contacts individually or in bulk using a CSV file.
To add contacts in bulk, ensure your CSV file contains user details formatted correctly. You can create this file using Google Sheets or Excel. Remember, the CSV can have a maximum size of 50 MB and up to 200,000 contacts.
  • Click on “Add New File” to upload your CSV.
  • Drag and drop your CSV file into the upload area.
  • Click on the “Upload Files” button to complete the process.
After successfully uploading, your contacts will be available for broadcasting messages through Pabbly Connect. This saves you time and ensures efficient communication.
4. Setting Up Your Broadcast Message with Pabbly Connect
Now, you are ready to set up your broadcast message. Go to the “Broadcast” feature in Pabbly Connect. Click on the “Plus Add Broadcast” button to create a new broadcast campaign.
Here, you will need to name your broadcast and select the contact list you created earlier. You can also refine your audience by excluding specific contacts if needed. Opt for a pre-approved template message for compliance with WhatsApp guidelines.
  • Select the broadcast type as “Broadcast Campaign”.
  • Choose your message type and select the WhatsApp template.
  • Add any images or additional content as necessary.
After setting everything up, click on the “Done” button. You can test your broadcast by entering a test number and clicking on “Send Test Message”. This step ensures everything is functioning correctly before the actual broadcast.
5. Scheduling Your Broadcast with Pabbly Connect
Finally, you can schedule your broadcast for a later date. In the broadcast setup, select the “Schedule Broadcast” option. Choose the date and time when you want your message to be sent out to your contacts.
Simply click on the “Plus Add Broadcast” button once you have set the schedule. You will see a confirmation that your broadcast has been successfully scheduled. This feature allows you to plan your marketing efforts effectively using Pabbly Connect.
Additionally, you can track the status of your broadcast by clicking on the “View Stats” button. This provides insights into delivery, read rates, and any failures. By using Pabbly Connect, you can manage your WhatsApp broadcasts seamlessly and efficiently.
Using Pabbly Connect for WhatsApp broadcasting allows businesses to reach thousands of users instantly. This tutorial detailed how to set up templates, add contacts, and schedule broadcasts effectively. Embrace the power of Pabbly Connect to enhance your marketing strategy.
