To start automating your WhatsApp leads into GoHighLevel, you need to access Pabbly Connect. Simply visit the Pabbly website and navigate to the Connect section. If you’re a new user, sign up for a free account to get 100 free tasks each month, allowing you to test this automation.
Once logged in, you will be greeted by a user-friendly interface. From here, you can create new workflows that will facilitate the integration between WhatsApp and GoHighLevel through Pabbly Connect. This process is straightforward and requires no coding skills.
The next step involves setting up the trigger in your Pabbly Connect account. The trigger you will use is “Pabbly Chatflow Contact Created”. This means every time a new contact is created in your Pabbly Chatflow, it will trigger the workflow to create a corresponding contact in GoHighLevel.
  • Select “Pabbly Chatflow” as your trigger application.
  • Choose “Contact Created” as the trigger event.
After copying the webhook URL, navigate to your Pabbly Chatflow account. Go to the Settings option, and then to the API and Webhook section. Here, click on the “Add Webhook” button and paste the copied URL. Name the webhook as “New Contact” and save it. This will ensure that every new contact created in Pabbly Chatflow will be forwarded to Pabbly Connect.
3. Creating Contacts in Pabbly Chatflow
Now that your trigger is set up, you can create contacts directly in your Pabbly Chatflow account. For demonstration, you can manually add a contact with the name “Test Demo 999” and the corresponding phone number. Once this contact is created, it will automatically trigger the workflow in Pabbly Connect.
To ensure everything is working correctly, refresh your GoHighLevel contacts page. You should see the contact “Test Demo 999” appear, confirming that the integration is functioning as intended. This process allows you to manage your WhatsApp leads effectively by automatically syncing them with your GoHighLevel account.
4. Finalizing the Integration with GoHighLevel
With the contacts created in Pabbly Chatflow, the next step is to finalize the integration with GoHighLevel. In your Pabbly Connect workflow, select “GoHighLevel” as the action application. Choose “Create Contact” as the action event. This will allow you to send the contact information from Pabbly Chatflow to GoHighLevel seamlessly.
  • Connect your GoHighLevel account by following the prompts.
  • Map the contact details from the previous step to ensure accurate data transfer.
  • Save and test the request to see if the contact appears in GoHighLevel.
After saving and testing, refresh your GoHighLevel contacts page again. You should see the newly created contact with the details you mapped. This confirms that Pabbly Connect effectively integrates WhatsApp leads into GoHighLevel, streamlining your lead management process.
5. Conclusion
In this tutorial, we demonstrated how to integrate WhatsApp leads into GoHighLevel using Pabbly Connect. By following these steps, you can automate your lead management and save time. With Pabbly Connect, you can easily manage contacts and enhance your business efficiency.
For any questions or further assistance, feel free to reach out. Automate your workflow today with Pabbly Connect and enjoy seamless integrations!
