1. Setting Up Pabbly Connect for Your AI Travel Agent
To create an AI-powered travel agent, the first step is accessing Pabbly Connect. This integration platform allows you to connect various applications seamlessly. Start by visiting pabbly.com/chatbot to create a free account, which grants you 100 free credits monthly.
Once signed up, navigate to the Pabbly Chatbot dashboard. Here, you will see multiple features on the left side. Click on the AI assistant feature to begin setting up your automated travel agent. This is where the magic of Pabbly Connect happens.
2. Creating Your AI Assistant Using Pabbly Connect
After accessing the AI assistant feature, click on the plus add AI assistant button. Name your assistant, such as “AI Travel Agent,” and click on the add AI assistant button. This is how you initiate the setup process with Pabbly Connect.
Once created, select the instruction type for your assistant. Here are the steps:
- Choose the AI agent option to generate predefined instructions.
- Set the temperature for creativity in responses; a lower value provides more accurate replies.
- Select OpenAI as the model provider and choose the GPT-4o mini variant.
Now, paste your OpenAI API key to connect it with Pabbly Connect, allowing your assistant to use AI capabilities effectively.
3. Configuring AI Assistant Settings in Pabbly Connect
In the assistant settings, you can customize various options. First, enable the header or footer message if desired. You can also set stop keywords, which will halt the assistant’s responses when triggered. This is crucial for user control within Pabbly Connect.
Next, define retry attempts, which determine how many times the AI will try to respond if there’s an issue. Additionally, you can set a fallback message for instances when the assistant fails to reply due to technical errors. This ensures a smooth experience for users interacting with your assistant.
4. Uploading Your Knowledge Base Using Pabbly Connect
The knowledge base is essential for your AI assistant to provide accurate replies. It serves as an information bank, containing all necessary data about your travel agency. Use Pabbly Connect to upload this knowledge base file by clicking the add new file option and selecting your document.
Ensure your knowledge base includes details like your business name, services, and goals. The file should be less than 90 MB, with no page limit for text files. However, if using images, keep it under 10 pages. This knowledge base enables your assistant to give specific and relevant responses.
5. Finalizing Your AI Travel Agent with Pabbly Connect
After uploading your knowledge base, customize the assistant interface. Change the heading to something like “Wonder Wise AI Travel Assistant” and adjust the initial messages to suit your business. This is where Pabbly Connect allows you to personalize your assistant’s interaction style.
To make your assistant accessible on your website, click on the embed option to get the necessary code. Copy and paste this code into your website’s HTML. This integration will allow your customers to interact with your AI travel agent directly from your site.
Lastly, enable the AI auto-reply settings in the inbox settings of Pabbly Chatbot. Select your created assistant and save the settings, making your travel agent fully operational.
In this tutorial, you learned how to create an AI-powered travel agent using Pabbly Connect. By following the steps outlined, you can automate travel planning for your customers efficiently. This setup allows your business to operate 24/7, enhancing customer experience without direct human intervention.
