1. Introduction to Pabbly Connect and Chatbot Integration
In this tutorial, we will explore how to use Pabbly Connect to turn WhatsApp into a smart banking assistant. This integration allows customers to receive instant responses to their banking queries.
Using Pabbly Connect, we can seamlessly link WhatsApp with a chatbot that handles customer inquiries, making banking services more accessible and efficient.
2. Setting Up Pabbly Connect for WhatsApp Chatbot
To begin, access Pabbly Connect and create a new workflow. This workflow will facilitate the connection between WhatsApp and the chatbot. Start by logging into your Pabbly Connect account.
Once logged in, follow these steps to set up your workflow:
  • Click on “Create New Workflow”.
  • Name your workflow appropriately, such as “WhatsApp Banking Assistant”.
  • Select the trigger event, which will be the keyword “hello” to initiate the chatbot.
After setting up the trigger, you can customize the actions that follow. This is where you will define what happens when a user sends the keyword.
3. Configuring the Chatbot Flow with Pabbly Chatflow
Next, we will use Pabbly Chatflow to design the chatbot interactions. This tool allows you to create engaging conversation flows for WhatsApp users.
In Pabbly Chatflow, follow these steps to create your chatbot:
  • Drag and drop the text message block to send a welcome message.
  • Add buttons for options like “Account Opening” and “Ask Question”.
  • Configure responses based on user selections, guiding them through the account opening process.
Each button should lead to a specific flow, and you can set up additional questions to gather information like the user’s name and city.
4. Integrating Google Sheets with Pabbly Connect
To store user data collected through the chatbot, we will integrate Google Sheets using Pabbly Connect. This will ensure all responses are saved automatically.
Here’s how to set it up:
  • In Pabbly Connect, create an API request to Google Sheets.
  • Use the webhook URL provided by Pabbly Connect to connect your chatbot flow.
  • Map the data fields to corresponding columns in your Google Sheet.
This integration allows you to keep track of all account opening requests and customer inquiries efficiently.
5. Finalizing Your Banking Assistant Chatbot
After setting up the chatbot and integrating Google Sheets, it’s time to finalize your workflow. Make sure to test each part of the process to ensure everything works smoothly.
In Pabbly Connect, save your workflow and check for any errors. You can also set up fallback messages to inform users about the status of their requests.
Once satisfied, you can promote your WhatsApp banking assistant to your customers, providing them with easy access to banking services.
By leveraging Pabbly Connect and Pabbly Chatflow, you can transform WhatsApp into a smart banking assistant. This integration allows for efficient customer service and data management, enhancing the overall banking experience.
