To begin automating your WhatsApp conversations, first, you need to access Pabbly Connect. Open your browser and navigate to www.pabbly.com/connect. Here, you can sign in to your existing account or create a new one.
Once logged in, you will be taken to the Pabbly Connect dashboard. This will serve as your central hub for managing all integrations. Ensure you familiarize yourself with the interface to make the setup process smoother.
2. Setting Up Your WhatsApp Chatbot with Pabbly Connect
Next, you will create your WhatsApp chatbot using Pabbly Connect and Pabbly Chatflow. Start by selecting the Chatflow option on the dashboard. You can then add your WhatsApp number by clicking on the “Add WhatsApp Number” button.
  • Click on “WhatsApp Connect” to link your WhatsApp account.
  • Choose to connect via manual token or through the preferred method.
  • Follow the prompts to complete the connection.
Once your WhatsApp number is connected, you can start creating your AI assistant. Click on the “AI Assistant” option on the left sidebar and name your assistant, such as “Fitness and Meal Business Bot.” This naming will help you identify your bot later.
3. Configuring Your AI Assistant in Pabbly Connect
With your assistant named, it’s time to configure its settings in Pabbly Connect. Set the instruction type to “AI Agent” and adjust the creativity level of the AI responses. A value of 0.7 is recommended for a balance between focus and creativity.
Next, you will need to enter your OpenAI API key. This is crucial for your AI assistant to function. You can obtain the API key from your OpenAI account by creating a new token. Ensure you save this key in the designated field in Pabbly Connect.
  • Toggle on the header and footer messages if you wish to provide additional context.
  • Set a stop keyword to halt AI responses if needed.
  • Adjust retry attempts for API responses as per your requirements.
After configuring these settings, click “Save” to ensure all changes are applied. This will finalize your AI assistant setup.
4. Embedding Your AI Assistant Using Pabbly Connect
Now that your AI assistant is configured, the next step is to embed it into your website. This is where Pabbly Connect truly shines, allowing seamless integration. Click on the “Embed” option to get the code needed for embedding.
Copy the provided code and paste it into your website’s HTML where you want the chatbot to appear. This will enable users to interact with your WhatsApp chatbot directly from your site, enhancing user engagement.
Additionally, you can assign this AI assistant to specific contacts or groups within your WhatsApp settings. This feature allows for targeted communication, ensuring that the right messages reach the right audience.
5. Finalizing Your Chatbot Setup with Pabbly Connect
Finally, review all settings and ensure that your AI assistant is active. In Pabbly Connect, you can check the status of your assistant and make any necessary adjustments. This includes toggling settings for auto-replies and assigning the assistant to various contact lists.
To assign your AI assistant, navigate to the inbox settings in Pabbly Connect. Here, you can select specific lists or all contacts to ensure your assistant is deployed effectively.
After confirming everything is set, click “Save” to finalize your setup. Your WhatsApp chatbot is now ready to engage with customers, providing them with timely information and responses.
In this tutorial, we explored how to automate WhatsApp conversations for your business using Pabbly Connect. By following the steps outlined, you can create an efficient chatbot that enhances customer interaction and satisfaction.
