To start using Pabbly Connect, you need to access the dashboard. Here, you can create a new workflow to integrate various applications. The first step is to click on ‘Create Workflow’ and name it “Turn Stock Market News into AI-powered Blog Post”.
After naming your workflow, select the folder where you want to save it. For this tutorial, choose the “All Automations” folder and click on ‘Create’. This sets the stage for the automation process using Pabbly Connect.
2. Setting Up RSS Trigger in Pabbly Connect
In this section, we will set up the RSS feed as the trigger in Pabbly Connect. The trigger is an event that initiates the workflow. Choose the RSS application and select the trigger event as “New Item in Feed”.
  • Enter the RSS feed URL, such as the one from Indian Express.
  • Set the default filter options as needed.
  • Click on ‘Save and Send Test Request’ to test the RSS connection.
Once you receive a positive response from the RSS feed, it confirms that the connection is successfully established. This ensures that any new stock market news will trigger the workflow through Pabbly Connect.
3. Creating Blog Post with OpenAI
Next, we will integrate OpenAI to generate a blog post from the RSS feed content. In Pabbly Connect, select OpenAI as the action application and choose the action event as “ChatGPT”.
To connect to OpenAI, if you have an existing connection, select it. Otherwise, click on ‘Add New Connection’ and enter your API key. After connecting, you will need to specify the AI model and write a prompt that instructs OpenAI to create an engaging blog post based on the RSS news.
  • Select the AI model (e.g., GPT-4).
  • Draft a prompt that summarizes the RSS news into a blog post.
  • Map the title and link fields from the RSS response.
Once you have set up these fields, click on ‘Save and Send Test Request’ to generate the blog post. This will confirm that OpenAI is properly integrated with Pabbly Connect.
4. Posting the Blog on Facebook
The final step is to share the generated blog post on Facebook. In Pabbly Connect, select Facebook as the action application and choose “Create Page Post” as the action event.
If you have an existing connection, select it. If not, click ‘Add New Connection’ and log in to your Facebook account. Choose the page where you want to post and then map the content generated by OpenAI into the post.
  • Ensure the post content includes the blog title and link.
  • Click ‘Save and Send Test Request’ to publish the post.
After executing the test request, you should see the blog post appear on your Facebook page. This confirms that the entire workflow from RSS to OpenAI to Facebook is functioning seamlessly through Pabbly Connect.
5. Conclusion
In this tutorial, we demonstrated how to integrate Pabbly Connect with RSS and OpenAI to automate the sharing of stock market news on Facebook. By following these steps, you can effectively streamline content creation and sharing for your audience.
Utilizing Pabbly Connect in this way not only saves time but also enhances engagement with AI-generated content. Start automating your workflows today!
