1. Introduction to Automating Shopify with Pabbly Connect
In this section, we will discuss how to automate order confirmation emails using Pabbly Connect. This automation is crucial for enhancing customer experience by sending immediate confirmations for Shopify orders.
When you integrate Shopify with Gmail through Pabbly Connect, you can eliminate the tedious task of manual email sending. This integration ensures that every customer receives a personalized order confirmation instantly after their purchase.
2. Setting Up Pabbly Connect for Shopify Integration
To begin, access Pabbly Connect by signing up at pabbly.com/connect. After signing up, you will have access to 100 free tasks every month to explore the software.
Once you log into your Pabbly Connect dashboard, click on the “+ Create Workflow” button. You will see options to create workflows using different methods, but we will select the “Create Using Quick Builder” option for simplicity.
  • Click on the “+ Create Workflow” button.
  • Select “Create Using Quick Builder”.
  • Input a prompt to generate your workflow automatically.
After entering the prompt, Pabbly Connect will automatically set up the workflow, asking you to select the trigger from Shopify, which is “New Order” in this case.
3. Connecting Shopify to Pabbly Connect
Now that we have set up our workflow, it’s time to connect Shopify with Pabbly Connect. Click on the Shopify application in your workflow to generate a webhook URL.
Copy the webhook URL provided and head over to your Shopify account. Go to “Settings” and then to “Notifications”. Scroll down to find the “Webhooks” section and click on “Create Webhook”.
  • Select “Order Creation” as the event.
  • Paste the copied webhook URL.
  • Choose the API version as “Latest” and click “Save”.
Once saved, you have successfully connected Shopify to Pabbly Connect. Now, whenever a new order is placed, the webhook will trigger the workflow.
4. Setting Up Gmail Action in Pabbly Connect
Next, we will set up Gmail as the action application in our Pabbly Connect workflow. Click on the “Gmail” application and select “Send Email” as the action.
To connect your Gmail account, you can either choose an existing connection or create a new one. After connecting, fill in the sender name, recipient email, email subject, and email body using the mapping feature from the Shopify order data.
  • Enter the sender name as your store name.
  • Map the recipient email from the Shopify response.
  • Craft a personalized email subject and body.
After filling in all the details, click on “Save and Send Test Request” to verify the setup. You should receive a confirmation email in your Gmail account.
5. Finalizing the Workflow in Pabbly Connect
Now that the Gmail action is set up, it’s important to finalize the workflow in Pabbly Connect. Ensure that you enable the toggle switch to activate the workflow.
Once enabled, your workflow will automatically send order confirmation emails every time a new order is placed on your Shopify store. This automation not only saves time but also enhances customer satisfaction.
Remember, if you have any questions or face difficulties while creating this workflow, feel free to reach out in the comments. Also, don’t forget to use the coupon code MHYT for exclusive discounts on Pabbly subscriptions.
In this tutorial, we demonstrated how to automate Shopify order confirmations using Pabbly Connect and Gmail. By following these steps, you can streamline your order management process and enhance customer experience effectively.
