To start integrating your website leads with HubSpot, first access Pabbly Connect. You can do this by visiting the Pabbly website and signing in to your account. If you are new, sign up for a free account to get started.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create new workflows that automate tasks between your website and HubSpot. This is where the magic of Pabbly Connect begins, allowing seamless integration with just a few clicks.
In this section, you will create a new workflow that captures leads from your website. Click on the “Create Workflow” button on your dashboard. Name your workflow something descriptive, like “Landing Page Leads to HubSpot Contacts”.
  • Select a folder for your workflow.
  • Choose a trigger application, which will be Webhook by Pabbly.
  • Set the trigger event to “Catch Webhook”.
After setting this up, click on “Connect” to generate a webhook URL. This URL will be used to connect your website form to Pabbly Connect, allowing it to capture lead submissions automatically.
3. Setting Up the Webhook for Lead Capture
Now, you need to integrate the generated webhook URL with your website form. Open your form code in a text editor and replace any existing webhook URL with the new one provided by Pabbly Connect. Save your changes to ensure the form is linked correctly.
Once the webhook is set, submit a test entry through your website form. This will help you verify that Pabbly Connect is receiving the data correctly. Refresh your workflow page to check if the form submission details appear in your Pabbly Connect dashboard.
4. Adding HubSpot CRM Integration in Pabbly Connect
With the webhook now capturing data, the next step is to connect Pabbly Connect to HubSpot CRM. In your workflow, select HubSpot CRM as the action application and choose “Create Contact” as the action event.
  • If you have an existing connection, select it; otherwise, create a new connection.
  • Map the form fields to HubSpot fields, such as name and email.
This mapping ensures that every new lead captured from your website form is automatically added to your HubSpot CRM, streamlining your lead management process.
After setting up the HubSpot integration, it’s crucial to test the entire workflow. Submit another test lead through your website form, and check if the details appear in HubSpot CRM. This step confirms that Pabbly Connect is functioning correctly.
Once verified, you can monitor your Pabbly Connect dashboard for any new leads captured. This automated process significantly reduces manual work, allowing you to focus on converting leads into customers.
In this tutorial, we explored how to integrate your website leads with HubSpot CRM using Pabbly Connect. By automating the lead capture process, you can save time and improve your CRM efficiency.
