1. Accessing Pabbly Connect to Set Up Integration
To start integrating WooCommerce with Salesforce, the first step is to access Pabbly Connect. Visit the Pabbly website by typing pabbly.com in your browser. Once there, you can either sign in if you already have an account or sign up for free to get started.
After signing in, you will arrive at the Pabbly Apps page. Here, navigate to Pabbly Connect to access the dashboard where you can create and manage your workflows. This platform is essential for automating the integration between WooCommerce and Salesforce.
In this section, we will create a new workflow in Pabbly Connect. Click on the “Create Workflow” button and name it appropriately, such as “Turn Every WooCommerce Orders into Salesforce Sales Opportunity”. Select the desired folder where the workflow will be saved.
  • Click on “Create” to initiate the workflow.
  • Choose WooCommerce as the trigger application.
  • Select “New Order Created” as the trigger event.
After setting the trigger, Pabbly Connect will provide you with a webhook URL, which acts as a bridge between WooCommerce and the Pabbly platform. This URL is crucial for capturing order details automatically.
3. Connecting WooCommerce to Pabbly Connect
Now, let’s connect WooCommerce to Pabbly Connect. Go to your WordPress dashboard, navigate to WooCommerce settings, and select the advanced tab. From there, click on the Webhooks option to add a new webhook.
  • Name the webhook as “Salesforce” and set its status to active.
  • Set the topic to “Order Created”.
  • Paste the webhook URL from Pabbly Connect into the delivery URL field.
Once you save the webhook, WooCommerce will send order data to Pabbly Connect whenever a new order is placed, enabling seamless integration with Salesforce.
4. Testing the Integration Between WooCommerce and Salesforce
After setting up the webhook, it’s time to test the integration through Pabbly Connect. Click on “Recapture Webhook Response” in your workflow. This will prepare Pabbly Connect to receive data from WooCommerce.
Next, create a test order in your WooCommerce store. Fill in the necessary details like name, address, and payment method, then place the order. As soon as the order is confirmed, Pabbly Connect should capture the order details and display them in your workflow.
5. Adding Salesforce as an Action Step in Pabbly Connect
With the WooCommerce order successfully captured, the next step is to add Salesforce as an action in Pabbly Connect. Click on the “Add New Action Step” and select Salesforce as the action application.
  • Choose “Create Contact” as the action event.
  • Connect your Salesforce account to Pabbly Connect by granting the necessary permissions.
  • Map the order details from WooCommerce to the corresponding fields in Salesforce.
After mapping all required fields, click “Save and Send Test Request”. If successful, you will see the new contact created in Salesforce, confirming that the integration works flawlessly through Pabbly Connect.
In this tutorial, we explored how to integrate WooCommerce with Salesforce using Pabbly Connect. This integration automates the process of creating leads in Salesforce whenever a new order is placed in WooCommerce, enhancing efficiency and workflow management.
