To start integrating Typeform with Go High Level, you must access Pabbly Connect. Visit the Pabbly website by entering pabyt.com in your browser. This platform is essential for automating workflows between different applications.
Once on the website, sign in to your Pabbly account. If you are a new user, you can sign up for free and receive 100 tasks monthly. After logging in, navigate to Pabbly Connect from the dashboard to begin creating your integration workflow.
In this step, you will create a new workflow in Pabbly Connect to connect Typeform with Go High Level. Click on ‘Create from Scratch’ and name your workflow, such as “Turn Every Typeform Response into a CRM Contact Instantly.” Select the appropriate folder for organization.
- Click on ‘Create’ to establish your workflow.
- A trigger box will appear; this is where you define the starting event of your automation.
- Select Typeform as your trigger application and choose ‘New Entry’ as the trigger event.
After selecting the trigger, click on ‘Connect’ to establish a connection with Typeform. If you don’t have an existing connection, create a new one by clicking on ‘Add New Connection’ and granting permission to Pabbly Connect.
3. Configuring Typeform Connection in Pabbly Connect
Once connected to Typeform, you need to select the specific form you wish to use. In this case, choose the “Registration Form” from the dropdown menu. After selecting the form, click ‘Save’ and then ‘Send Test Request’ to ensure everything is functioning correctly.
- Make sure to perform a test submission to capture the webhook response.
- You can do this by copying the form link and pasting it into a new tab.
- Fill out the form fields with your test data and submit.
After submission, return to Pabbly Connect to confirm that the webhook response has been captured successfully. This step verifies that your Typeform integration is correctly set up and ready to work with Go High Level.
4. Adding Go High Level as the Action Application
Now that your Typeform is connected, the next step is to add Go High Level as the action application in Pabbly Connect. Search for “Lead Connector V2” in the action application options and select it. Choose the action event “Create Contact” and click on ‘Connect’ to establish the connection.
If you don’t have an existing connection, create a new one by clicking on ‘Add New Connection’ and logging into your Go High Level account. After logging in, select your sub-account to ensure the integration works correctly. Once connected, you will be able to map the fields from Typeform to Go High Level.
5. Mapping Fields from Typeform to Go High Level
In this final step, you will map the fields from your Typeform submission to the corresponding fields in Go High Level using Pabbly Connect. Instead of entering data manually, utilize the mapping feature to ensure that new responses are dynamically captured.
- Map the first name, last name, email, phone number, and city from Typeform to Go High Level.
- Ensure that all mapped fields are dynamic to avoid static data entries.
- Click ‘Save’ and ‘Send Test Request’ to finalize the integration.
Once you receive a positive response from Go High Level, you can check your contacts to confirm that the new lead has been created successfully. This completes the integration process, allowing for seamless automation of leads from Typeform to Go High Level using Pabbly Connect.
In this tutorial, you learned how to integrate Typeform with Go High Level using Pabbly Connect. This powerful automation allows you to capture form submissions and add them directly to your CRM, streamlining your business processes.
