To start automating the sharing of Pinterest pins to Facebook posts, access Pabbly Connect by visiting www.pabbly.com/connect. This platform simplifies the integration process between various applications, including Pinterest and Facebook.
If you’re a new user, sign up for free to receive 100 tasks each month. This allows you to test the integration setup without any initial investment. Once logged in, you can explore the features offered by Pabbly Connect for automating your workflows.
After accessing your Pabbly Connect account, navigate to the “Create Workflow” option. Here, you can set up the automation that shares your Pinterest pins as posts on your Facebook page.
- Click on “Create using Quick Builder”.
- Enter your request: “Share Pinterest pins as Facebook page post”.
- Approve and create the workflow.
Once you have created the workflow, it will automatically set up a trigger for new pins added to your specified Pinterest board. This is where Pabbly Connect excels, as it automates the process without requiring any coding skills.
3. Setting Up the Trigger for Pinterest Pins
Next, you need to configure the trigger within your Pabbly Connect workflow. This step ensures that every new Pinterest pin is detected and processed.
To do this, select the “Pinterest New Pin” option and connect your Pinterest account. You will need to grant access to Pabbly Connect so it can monitor your pins. Choose the board where you will be adding new pins, and then save your settings.
After saving, create a new pin in Pinterest. For example, you can upload an image of your jewelry set titled “Ruby Rose Jewelry Set”. Once the pin is published, return to your Pabbly Connect workflow and click on “Save and Send Test Request” to capture the new pin’s details.
4. Connecting Facebook to Pabbly Connect
With your Pinterest pin successfully captured, the next step is to connect your Facebook account to Pabbly Connect. This integration will allow you to share the captured pin as a post on your Facebook page.
- Select “Connect with Facebook Pages” from the connection options.
- Grant permission for Pabbly Connect to access your Facebook account.
- Choose the Facebook page where you want to post the pin.
After connecting, you will map the image URL from your Pinterest pin to the Facebook post. This ensures that the correct image is shared. Enter the title and description for the Facebook post as well, and then test the request to ensure everything is working properly.
To finalize your integration, click on the “Event and Test Request” button in Pabbly Connect. This will send the data to your Facebook page and create a new post with the Pinterest pin.
Once the test is successful, refresh your Facebook page to see the new post appear. For example, your post should display the “Ruby Rose Jewelry Set” image and its description. This seamless integration allows you to automate your social media presence without manual effort.
By using Pabbly Connect, you can connect multiple applications and streamline your marketing efforts. This method not only saves time but also enhances your brand visibility across platforms.
In this tutorial, we demonstrated how to use Pabbly Connect to automate sharing Pinterest pins as Facebook posts. This integration simplifies your workflow, allowing you to focus more on your business and less on manual posting.
